Your Portal Version: 1.0.2
Boardlink: http://bsforum.altervista.org/forum/portal.php
added some mod, and changed from Portal XL italian to board3..
searched around this sforum and other forums for some solution..
I've tried to put some html and BBC in the two custom block, but it doesn't work, as you can see here,look at the 2 red-bordered blocks...(Click on the image to enlarge)
someone could help me please ?
HTML in the 2 custom block
Re: HTML in the 2 custom block
Already set "use bbcode on custom block" to yes?
Its just above the Box where you entered your Tags (in ACP)
- phpBB.de User: JUJOLINA
- phpBB.com User: JUJOLINA
yes I've done but it doesn't seem to work.. ç__ç
but the code that have inside the blocks its not a bbcode even HTML.....if you click yes to able bbcode in box should work..... with the real bbcode.....are you brazilian???
only bbcode works, not html .. instead in the explanation text there's a wright that tells that also html should work...
No, I'm not brazilian, I'm Indian ( I come from India, but I'm adopted and I'm italian since 1984 )
