Friends show up twice in UCP!
Moderator: Dyo
luminosity
I just enabled the Friends module and every time a user adds a friend, they appear twice in the list of friends in the UCP. How can I fix this? I am using the mod Board3 Portal with Portalview.
Re: Friends show up twice in UCP!
Just to clarify:luminosity wrote:they appear twice in the list of friends in the UCP
They appear twice in the UCP or in the list of the portal?
luminosity
They appear only ONCE EACH in online_friends.html block. They appear TWICE EACH in the friends tab in the UCP. However, the online_friends.html block will also show the friends twice when a user is in any tab in the UCP. When on other forum pages, the online_friends.html block displays correctly.
luminosity
I think I found something related in the memberlist_view.html
<!-- IF S_USER_LOGGED_IN and S_ZEBRA -->
<!-- IF U_ADD_FRIEND -->
<dt> </dt> <dd><a href="{U_ADD_FRIEND}">Collaborate: Add Friend</a></dd>
<dt> </dt>
<!-- IF U_REMOVE_FRIEND -->
<dt> </dt> <dd><a href="{U_REMOVE_FRIEND}"><strong>{L_REMOVE_FRIEND}</strong></a></dd>
<!-- ENDIF -->-
luminosity
Here's what my ucp_zebra_friends.html looks like.
<!-- INCLUDE ucp_header.html -->
<form id="ucp" method="post" action="{S_UCP_ACTION}"{S_FORM_ENCTYPE}>
<h2>{L_TITLE}</h2>
<div class="panel">
<p>{L_FRIENDS_EXPLAIN}</p>
<fieldset class="fields2">
<!-- IF ERROR --><p class="error">{ERROR}</p><!-- ENDIF -->
<dl>
<dt><label <!-- IF S_USERNAME_OPTIONS -->for="usernames"<!-- ENDIF -->>{L_YOUR_FRIENDS}:</label><br /><span>{L_YOUR_FRIENDS_EXPLAIN}</span></dt>
<dd>
<select name="usernames[]" id="usernames" multiple="multiple" size="5">{S_USERNAME_OPTIONS}</select>
<strong>{L_NO_FRIENDS}</strong>
</dd>
</dl>
<dl>
<dt><label for="add">{L_ADD_FRIENDS}:</label><br /><span>{L_ADD_FRIENDS_EXPLAIN}</span></dt>
<dd><textarea name="add" id="add" rows="3" cols="30" class="inputbox">{USERNAMES}</textarea></dd>
<dd><strong><a href="{U_FIND_USERNAME}" onclick="find_username(this.href); return false;">{L_FIND_USERNAME}</a></strong></dd>
</dl>
</fieldset>
<fieldset class="submit-buttons">
{S_HIDDEN_FIELDS}<input type="reset" value="{L_RESET}" name="reset" class="button2" />
<input type="submit" name="submit" value="{L_SUBMIT}" class="button1" />
{S_FORM_TOKEN}
</fieldset>
</form>
<!-- INCLUDE ucp_footer.html -->-
luminosity
and this is what my online_friends.html block looks like:
<div class="forabg">
<div class="inner">
<ul class="topiclist">
<li class="header"><dl><dt><a href="/ucp.php?i=168">Collaborate</a></dt></dl></li>
<ul class="topiclist forums">
<li><dl>
<dd class="posts_portal" style="border-left:0px;width:100%">
<table width="100%">
<a href="/ucp.php?i=168"><em>{L_FRIENDS_ONLINE}</em></a>
<!-- BEGIN friends_online -->
<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/member.gif" height="15" width="15" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;">{friends_online.USERNAME_FULL}</span><br style="clear:both" />
<!-- BEGINELSE -->
<span style="float:left; padding-left:5px; padding-top:2px;"><a href="/ucp.php?i=168"><strong>{L_NO_FRIENDS_ONLINE}</strong></a></span>
<!-- END friends_online -->
<a href="/ucp.php?i=168"><em>{L_FRIENDS_OFFLINE}</em></a><br />
<!-- BEGIN friends_offline -->
<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/member.gif" height="15" width="15" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;">{friends_offline.USERNAME_FULL}</span><br style="clear:both" />
<!-- BEGINELSE -->
<span style="float:left; padding-left:5px; padding-top:2px;"><a href="/ucp.php?i=168"><strong>{L_NO_FRIENDS_OFFLINE}</strong></a></span>
<!-- END friends_offline -->
</dd>
</dl></li>
</div>-
I guess that will basically be the same thing as we had with the changing user menu: viewtopic.php?p=11937#p11937
The same template vars processed double.
