Boardlink: http://www.tekno.web.id
Install the phpBB3 Portal
I want To Ask some Question
I have Problem with My Portal
because i want to Use phpbb Seo on My Portal
but I Can't to Developt that, can you Solve this Problem ?
I mean, i want to made all of my post in my portal was optimized by phpbb-seo.com
i use the advanced SEO
you can answer this question by send email to admin@coderpro.org
I REALLY NEED YOUR HELP
Permalinks on phpBB3 Portal
- phpBB.de User: SmarterDOS
- phpBB.com User: SmarterDOS
- Valued Contributor
- phpBB.de User: scwfan06
- phpBB.com User: scwfan06
Re: Permalinks on phpBB3 Portal
That´s the solution, i think!
knowledge/kb_show.php?id=46
thanks! that´s it!
