Your Portal Version:
I have noticed something strange about the User Menu. When a user clicks on another user and sees their profile, the Avatar, username and user's rank in the User Menu changes to reflect the person you are looking at, not your own. Then when you navigate away from that user's profile, the User Menu returns to normal; displaying your avatar and username. I think that is confusing for the user. The User Menu should always show the user's info. How can I correct this?
Avatar in User Menu changes when looking at other profiles
Moderator: Dyo
luminosity
Re: Avatar in User Menu changes when looking at other profiles
Erm, are you using the mod portalview?
Otherwise i can't imagine how it would be possible to see a user profile at the same time with the portal user menu.
luminosity
Yes, I am using the mod portalview. Sorry for not mentioning it before.
Moved to the proper forum.
Funny bug. It comes from double assigned template vars. User menu / memberlist. The user menu gets now the template vars from the memberlist.php, as they have been processed last (with the data from the user you are watching the profile).
So we need to name them different in the user_menu.php and user_menu.html
Open user_menu.php
search:
replace with:
As you see i have just added _P to the names. Now go and do the same for these 8 template vars in the user_menu.html.
e.g the subsilver user_menu would look like this:
That will fix it.
Open user_menu.php
search:
'AVATAR_IMG' => $avatar_img,
'RANK_TITLE' => $rank_title,
'RANK_IMG' => $rank_img,
'RANK_IMG_SRC' => $rank_img_src,
'USERNAME_FULL' => get_username_string('full', $user_id, $username, $colour),
'USERNAME' => get_username_string('username', $user_id, $username, $colour),
'USER_COLOR' => get_username_string('colour', $user_id, $username, $colour),
'U_VIEW_PROFILE' => get_username_string('profile', $user_id, $username, $colour), Code: Select all
'AVATAR_IMG_P' => $avatar_img,
'RANK_TITLE_P' => $rank_title,
'RANK_IMG_P' => $rank_img,
'RANK_IMG_SRC_P' => $rank_img_src,
'USERNAME_FULL_P' => get_username_string('full', $user_id, $username, $colour),
'USERNAME_P' => get_username_string('username', $user_id, $username, $colour),
'USER_COLOR_P' => get_username_string('colour', $user_id, $username, $colour),
'U_PROFILE_P' => get_username_string('profile', $user_id, $username, $colour), e.g the subsilver user_menu would look like this:
<!--version $Id: user_menu.html 344 2008-08-24 20:50:39Z kevin74 $ //-->
<th><span style="float: left"><img src="{T_THEME_PATH}/images/portal/portal_user.png" width="16px" height="16px" alt="" /> {L_USER_MENU}</span></th>
<tr class="row1">
<td>
<div align="center">
<a href="{U_VIEW_PROFILE_P}"><!-- IF USER_COLOR --><span style="color: {USER_COLOR_P}; font-weight: bold;"><!-- ELSE --><span><!-- ENDIF -->{USERNAME_P}</span></a><br />
<a href="{U_PROFILE_P}"><!-- IF AVATAR_IMG -->{AVATAR_IMG_P}<!-- ELSE --><img src="{T_THEME_PATH}/images/no_avatar.gif" alt="" /><!-- ENDIF --></a>
<!-- IF RANK_TITLE --><br /><span class="gensmall">{RANK_TITLE_P}</span><!-- ENDIF -->
<!-- IF RANK_IMG --><br />{RANK_IMG_P}<!-- ENDIF -->
</div><hr />
<!-- IF S_DISPLAY_SEARCH -->
<a href="{U_NEW_POSTS}">{L_NEW_POSTS}</a><br />
<a href="{U_SELF_POSTS}">{L_SELF_POSTS}</a><br />
<!-- IF U_UM_BOOKMARKS -->
<a href="{U_UM_BOOKMARKS}">{L_UM_BOOKMARKS}</a><br />
<a href="{U_UM_MAIN_SUBSCRIBED}">{L_UM_MAIN_SUBSCRIBED}</a><br />
<!-- IF S_DISPLAY_PM -->
<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>
<hr />
<a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a>
<br /> ~~~ They say the definition of madness is doing the same thing and expecting a different result ~~~
luminosity
Thanks! That worked beautifully !!
