i use prosilver.. can anyone giva a tutor?
fresh installation with prosilver
kuikui
- phpBB.com User: BaikPunyo
the menu button should has own background right? and also all the blocks? mine was nothing there..
Re: fresh installation with prosilver
Make sure you uploaded the portal.css and modified the stylesheet.css as stated in the install.xml. Also refresh you theme cache as stated in the following KB article: knowledge/kb_show.php?id=28
kuikui
it's work..
thanks marc
