Your Portal Version: 1.0.02
I installed board3 on localhost.
phpbb 3.04 moded & fresh both I trried. There are no menus/boxes except recent topic shows. Installed with automod & manual.
No luck.
Need suggestion what to do.
regards
SOLVED-Both side menu/boxes disappear
- phpBB.de User: sbashwar
- phpBB.com User: sbashwar
Re: Both side menu/boxes disappear
did you enable all blocks in ACP and purge the cache????
on localhost install_portal did not finish properly. ACP was not available.
Now I installed it successfully on host server under test directory. It works fine.
Excellent portal.
Thanks for reply.
Excellent portal.
Thanks for reply.
