How to change the Menu Look/Content?
gamerbum12
Post by gamerbum12 »
Your Portal Version: 1.0.2
Boardlink: http://theheartbreakers.comli.com
I tried to search for custom menu look...but couldnt find anything on your site or google :/
Nothing really, I don't know where to start...
Okay I want to change the look and maybe change some content in the menu of my site. Im not sure on where to start and how to do this. If any of you can help, that would be awesome...
I took a couple screenshots of what Im talking about:
This is what I have now:
This is how I sort of want it to look, just dont look at the colors, just the style:
Thanks!
japagun
phpBB.com User: japagun
Re: How to change the Menu Look/Content?
Post by japagun »
can you edit main menu block with your desire HTML codes.....
gamerbum12
no i dont know how, if you're asking me...or are you just asking like if its possible...
japagun
Post by japagun »
gamerbum12 wrote:no i dont know how, if you're asking me...or are you just asking like if its possible...
yes its possible, just edit the main_block.html in your template.
