How to get subforums onto the News section
Oshadha
Post by Oshadha »
I tried adding forum ID's but it didn't work my forum only contains subforums. all the others are Categories
for example Movies(this is a Category) --- > English Movies(Subforum 1)
|----> Hindi Movies(Subforum 2)
Please someone help me to add these sunforums to the News section of my Portal
Thank You...
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Re: How to get subforums onto the News section
Post by thomas.d »
Hm, subforums are displayed (as long as the correct forum ID is entered ...)
Did you seperate them with a comma (i.e. 30,35,50,65)?
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Oshadha
Post by Oshadha »
Ok but how can exactly find a valid forum ID within my forum
Oshadha
Post by Oshadha »
Please someone reply
japagun
phpBB.com User: japagun
Post by japagun »
just enter in forum that you want to include and see in your browser.. something like this...
viewforum.php?f=10 10 is our forum ID.
Oshadha
Post by Oshadha »
Thank you very mush japagun, But now im facing another problem, i need to add some forums to my Global Announcements section ,as u mentioned i got the forum and i added it in to the section which asks for the forum ids in Global Announcements settings section. But it didn't work Global Announcements shows up nothing, please can you figure this out.
viewforum.php?f=45
therefor my forum ID is 45.
Oshadha
Post by Oshadha »
Please someone help
thomas.d
Post by thomas.d »
Oshadha wrote:(Mo 16. Feb 2009, 04:16) Ok but how ...
Oshadha - bumping - wrote:(Mo 16. Feb 2009, 06:41) Please someone reply
Oshadha wrote:(Mo 16. Feb 2009, 07:22) ... please can you figure this out.
Oshadha - bumping - wrote:(Mo 16. Feb 2009, 14:24) Please someone help
Board3.de Rules wrote:...
  • Topic-Bumping is only accepted at least 24 hrs. after posting.
Thomas
Oshadha
Post by Oshadha »
Still i didn't sort it out . someone please reply
Hows about a Link to your Portal?
And what is your exactly Problem. Like Thomas already said, normaly subforums are displayed...
thomas.d wrote:Hm, subforums are displayed (as long as the correct forum ID is entered ...)
If you dont enter any numbers, it should display all Announcements in there (given that you have any)
japagun
Post by japagun »
Oshadha when you make a Global Announcements you have to set in post in check box above save preview submint buttons to see in portal
Oshadha
Post by Oshadha »
I put the right forum ID and I'm 100% sure about it, but it only displays the bar no announcements at all, also the same when I put nothing to the forum ID field, I cant give you a forum link because it's in my local machine I'm still setting up my portal (still didn't host it).
Here are some screen shots:
http://www.freeimagehosting.net/image.p ... 8de068.jpg
http://www.freeimagehosting.net/image.p ... 687dd9.jpg
Thanks
Check your board, if you have announcements, and if they are not older than you have entered in the settings.
EDIT: I edid your Posting since the Image Tag dont work with php files.
And now i can see that you have disabled "display global announcement".
Thats the same as you complain about darkness, but dont switch the light on... :?
And if you set "number of days to display the announcement" to 4 days, then your announcements has to be younger than that.
Oshadha
Post by Oshadha »
Thank you very much Mike, now you like a god to me....
:D
Did that mean you solved the problem?
And if so, what was the key?
