Boardlink: http://forum.enz.ir
My problem is that in firefox bullets in bulleted items nearly stick to blocks. Please take a look at them in the LINKS section.
What can I do ?
Thx
Bullets interfering
Re: Bullets interfering
Another thing
When now I tried to use another language (Persian) , in IE the left side of the frames got lost and in Firefox again bullets interfered. Seems it is because that language is right to left. I think there should be an option for being able to change the size of three columns of the portal independently ! Anyway when I make that ltr by editing its common.php again bullet thing ...
it seems to be an style issue - check the stylesheet used for this portal style - have a look to "ul" or "li". I am quite sure it doesnt have the proper padding or margin...
It is quite bugless in IE , problem is in Firefox.
Anyway what should I do with that stylesheet file ?
