Links buttons
Conditor
Links buttons
Post by Conditor »
Boardlink: http://forum.conditor.be
Nothing
searching
Hello again,
Next question, sorry to be so noobish...
There is a links block, where u can type in text and a url.. now my question is:
Instead of text i want a button in there.. i tried with [img] tags and with html, both didn't work.. is there a way to add buttons (images) instead of plain text?
Thanks in advance!
PeterS
phpBB.de User: PeterS
phpBB.com User: PeterS
Re: Links buttons
Post by PeterS »
Hello again,
i didn´t think so at the moment, but i use the middle custom block to show credit buttons from friends an partners.
greetz Peter
Conditor
Re: Links buttons
Post by Conditor »
If i didn't use that one allready i could have used it :-)
Is there a way to get more "custom" blocks in the middle? atm i'm using the side and middle block allready, and don't wanna change them for the links
maybe there is a mod for it?
Greetz
PeterS
Re: Links buttons
Post by PeterS »
Conditor
Re: Links buttons
Post by Conditor »
Great thanks, i'll give that a go.
I'll let you know if i got it to work, knowing me i'll screw up somewhere in the process :-p
Conditor
Re: Links buttons
Post by Conditor »
Like i said..
Somehow i can't get it to work :-/
I made a copy of:
/forum/styles/SF_Glacier_Lite/template/portal/block/custom_small.html
And called it
/forum/styles/SF_Glacier_Lite/template/portal/block/custom_small2.html
Then i changed the code to:
<!--version $Id: custom_small2.html 236 2008-05-18 15:50:06Z kevin74 $ //-->
<div class="portal-panel">
	<div class="inner">
			<h3><img src="{T_THEME_PATH}/images/portal/portal_menu.gif" width="18px" height="18px" alt=""/>&nbsp;Link Partners</h3>
				<div class="content"><a href="http://www.starlightweb.nl/nuke-evo"><img src="http://www.starlightweb.nl/nuke-evo/images/evo/ministar.gif" alt="Starlightweb" title="Starlightweb" border="0" /></a></div>
<br style="clear:both" />
Then i opened:
/forum/styles/SF_Glacier_Lite/template/portal/portal_body.html
And changed the code to:
<!-- IF S_DISPLAY_USERMENU -->
				<!-- INCLUDE portal/block/login_box.html -->
              <!-- IF S_CUSTOM_SMALL2 -->
			<!-- INCLUDE portal/block/custom_small2.html -->
				<!-- INCLUDE portal/block/user_menu.html -->
And i don't see the block.
Where did it go wrong??
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Re: Links buttons
Post by thomas.d »
Did you refresh the template- and theme cache?
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Conditor
Re: Links buttons
Post by Conditor »
Yes, i did that
I also moved 1 block (the custom_small) and that i can see after a refresh of the cache.
But i can't see the new block
Re: Links buttons
Conditor wrote:Then i opened:
This is a bit mixed up, i guess. Try this:
            <!-- ENDIF -->
            <!-- ENDIF -->
        <!-- ENDIF -->
Conditor
Re: Links buttons
Post by Conditor »
That is great!!!
So now it's just a mather of renaming them and place them that way.
Thanks alot, this was a great help and it's solved :-)
Re: Links buttons
Just to explain:
  1. You've placed the new block within a switch for the usermenu. You have to keep it outside.
  2. If you want to use a switch like <!-- IF S_CUSTOM_SMALL2 --> - it has to be defined somewhere and set to "TRUE". Otherwise it will always be "FALSE" and nothing is displayed.
    So just insert the include - without a not defined switch. ;)
nedumeritu
phpBB.de User: nedumeritu
phpBB.com User: nedumeritu
Re: Links buttons
Post by nedumeritu »
Kevin wrote:Just to explain:
And so, everything can be great but you forgot to show us the final codes.
The theory is fine. But the practice will kill us.
Re: Links buttons
I showed the code as a solution above, as i saw the problem. It was never my intention to "show you the final codes". There was a clear question and i answered it.
What are planning to do? Just complaining wont get you further.
nedumeritu wrote:The theory is fine. But the practice will kill us.
That sounds bad. You better think about it, if it is the right thing for you to do. ;)
