http://www.lithiumstudios.org/forum/vie ... =31&t=1114This mod displays a list of users who have been registered for X years on the index.
So, for example, if I would have registered on January 25, 2000, I would show up on the list tomorrow (Jan 25, 2009) as EXreaction (9).
Exreaction's Anniversary List
I would like to have a block for the following mod.
Re: Exreaction's Anniversary List
As first: I neither give guarantee that this Mod works corrrectly, nor did I Support this Mod.
I only altered the install instructions to enable it in your Portal.
You dont need to download anything... Just follow this instructions.
This Mod is testet, and my Portal is still running
If you dont see the Block, it is because you dont have any anniversarys.
If you have trouble to install this Mod in your Portal, ask here. If you want to have Support for this Mod itself, ask the Autor (link above)
Backup your files, if anything goes wrong...
let's start...
Open: /language/en/mods/lang_portal.php
Create: anniversary.php
in: portal/block/
paste the following Content in this file
Open: portal.php
for prosilver:
make a new Block in: styles/prosilver/template/portal/block/, called anniversary.html and paste in the following code:
for subsilver2:
make a new Block in: styles/subsilver2/template/portal/block/, called anniversary.html and paste in the following code:
Open: portal_body.html
let's start...
'ANNIVERSARY_LIST' => 'Anniversary List',
in: portal/block/
* @package - Board3portal
* @version $Id: anniversary.php 325 2008-08-17 18:59:40Z kevin74 $
if (!defined('IN_PHPBB'))
exit;
if (!defined('IN_PORTAL'))
exit;
// Generate anniversary list
$anniversary_list = $cache->get('anniversary_list');
if ($anniversary_list === false)
$anniversary_list = '';
$current_date = date('m-d');
$current_year = date('Y');
$leap_year = date('L');
$sql = 'SELECT user_id, username, user_colour, user_regdate
FROM ' . USERS_TABLE . "
WHERE user_type IN (" . USER_NORMAL . ', ' . USER_FOUNDER . ')';
// We are compensating for leap year here. If the year is not a leap year, the current date is Feb 28, and they joined Feb 29 we will list their names.
if (date('m-d', $row['user_regdate']) == $current_date || (!$leap_year && $current_date == '02-28' && date('m-d', $row['user_regdate']) == '02-29'))
if (($current_year - date('Y', $row['user_regdate'])) > 0)
$anniversary_list .= (($anniversary_list != '') ? ', ' : '') . get_username_string('full', $row['user_id'], $row['username'], $row['user_colour']);
$anniversary_list .= ' (' . ($current_year - date('Y', $row['user_regdate'])) . ')';
$db->sql_freeresult($result);
//Figure out what tomorrow's beginning time is based on the board timezone settings and have the cache expire then.
$till_tomorrow = gmmktime(0, 0, 0) + 86400 - ($config['board_timezone'] * 3600) - ($config['board_dst'] * 3600) - time();
$cache->put('anniversary_list', $anniversary_list, $till_tomorrow);
$template->assign_var('ANNIVERSARY_LIST', $anniversary_list);
$template->assign_vars(array(
'PORTAL_LEFT_COLUMN' => $portal_config['portal_left_column_width'],
'PORTAL_RIGHT_COLUMN' => $portal_config['portal_right_column_width'],
include($phpbb_root_path . 'portal/block/anniversary.'.$phpEx);
<!--version $Id: anniversary.html 236 2008-05-18 15:50:06Z kevin74 $ //-->
<div class="portal-panel">
<div class="inner">
<h3><img src="{T_THEME_PATH}/images/portal/portal_birthday.gif" width="18px" height="15px" alt=""/> {L_ANNIVERSARY_LIST}</h3>
<p>{L_CONGRATULATIONS}: <strong>{ANNIVERSARY_LIST}</strong></p>
<br style="clear:both" />
<!--version $Id: anniversary.html 216 2008-04-29 07:23:22Z kevin74 $ //-->
<table class="tablebg" width="100%" cellspacing="1">
<th><span style="float: left"><img src="{T_THEME_PATH}/images/portal/portal_birthday.png" width="16px" height="16px" alt="" /> {L_ANNIVERSARY_LIST}</span></th>
<tr class="row1">
<td style="padding:5px 5px 5px 5px;">
<div class="postbody">
<br clear="all" />
<!-- IF S_DISPLAY_BIRTHDAY_LIST -->
<!-- INCLUDE portal/block/birthday_list.html -->
<!-- IF ANNIVERSARY_LIST -->
<!-- INCLUDE portal/block/anniversary.html -->
Reason: proper version
Now i have an anniversary, and therefore i can say: it works perfectly
