No borders around left and right side blocks
Your Portal Version: 1.0.2
Boardlink: http://www.crustygamers.com
nothing
reviewed all files with portal install to make sure all were correctly uploaded
I have searched all topics about this and can't seem to find a solution, my left and right blocks on my portal have no borders like the center blocks do, now I need to add that I'm using the SE_Pro style, if that might have anything to do with it.
I have purged my main cache and refreshed the template, theme and imageset, nothing has changed.
any help would be appreciated.
nothing
- phpBB.de User: Christian_N
- phpBB.com User: Christian_N
Re: No borders around left and right side blocks
Topic closed:
- "No-Go's"
- We will not provide support to those who have removed our credits from their portal.
If our credit re-insert it like to open a new topic.
Oh sorry Credit is only hidden
reopen topic.![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
Please download this adaptation: http://www.board3-styles.de/downloads.p ... l&df_id=36
Demo: http://demo.board3-styles.de/portal.php?style=22
![Verlegen :oops:](./images/smilies/icon_redface.gif)
reopen topic.
But he want to have the same border around the left and right blocks, like the blocks in center.
The style adaption you linked doesnt have![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Yes exactly mike! any help would be appreciated
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Nevertheless: Invisible credits (white fore- and background) have the same quality as removed credits! You can't see them.
There is no reason to make credits invisible unless they shall not bee seen.
I strongly recommend to format the credits in a correct and fair way.
Thanks.
Thanks.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
HE dont make them invisible, since it was the Style. If you dont pay specific attention on this line, it is easy to miss. I Installed this Style too, and never noticed this white line. ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Mike is correct, it is the style that is causing the credit to be hidden, I missed it as well. I would be more than happy to fix it, I'm just not sure how?
To solve you problem with invisible Credits
open
styles/se_pro/template/portal/portal_body.html
find this line:
and replace with:
EDIT:
To have the same Borders around all Blocks you have to do a lot of changes on all side Blocks.
Since you need a lot of experience in this i wouldnt advise you to do this (unless you know what you do)
If i where you, i would wait until the next release of Board3 Portal (1.0.3), wich allows you to easily made this changes by yourself in one single file...![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
open
find this line:
<br /><div style="color:black; text-align: center">{L_PORTAL_COPY}</div>
EDIT:
Thanks Mike! I changed the code and now the credit shows up perfectly.
I will wait for the next release to fix the border problem, thanks again for all your help.
I`m really happy to see this reply.......Mike wrote:To solve you problem with invisible Credits
open
find this line:
and replace with:Code: Select all
EDIT:
Which part of it?
Thanks!FLATTOP wrote:... I changed the code and now the credit shows up perfectly. ...
Thomas
Thomas
ThisMike wrote:Which part of it?
