Ventrilo Block
Ventrilo Block
I see there is a Teamspeak block, any chance of someone making a Ventrilo block?
Re: Ventrilo Block
This is what we do for vent
http://www.instantventrilo.com/ventrilo ... status.php
Basically i IFRAME it.
You can see it on our website @ www.attackforcez.com. Click our emblem to enter the portal... it's on the right.
Re: Ventrilo Block
Thanks ROCOAFZ
I think that is what i will use, i was using a status block from my provider and didn't like it. It had scroll bars all the time, if I hide the scroll bars the users online got cut off. I like the one you suggest as it uses a java script and is dynamic. Thank you, feel free to check out our site, www.sourceofevil.com
