Boardlink: http://parksteels.co.uk/forum
PHP Version: php3.0.4
Nothing
Looked in all folders for the file
installed and got this error
[phpBB Debug] PHP Notice: in file /portal/block/mini_cal.php on line 26: include_once(.//portal/includes/mini_cal/mini_cal_config.php) [function.include-once]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /portal/block/mini_cal.php on line 26: include_once() [function.include]: Failed opening './/portal/includes/mini_cal/mini_cal_config.php' for inclusion (include_path='.:/usr/local/php52/pear')
[phpBB Debug] PHP Notice: in file /portal/block/mini_cal.php on line 27: include_once(.//portal/includes/mini_cal/mini_cal_common.php) [function.include-once]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /portal/block/mini_cal.php on line 27: include_once() [function.include]: Failed opening './/portal/includes/mini_cal/mini_cal_common.php' for inclusion (include_path='.:/usr/local/php52/pear')
[phpBB Debug] PHP Notice: in file /portal/block/mini_cal.php on line 28: include_once(.//portal/includes/mini_cal/calendarSuite.php) [function.include-once]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /portal/block/mini_cal.php on line 28: include_once() [function.include]: Failed opening './/portal/includes/mini_cal/calendarSuite.php' for inclusion (include_path='.:/usr/local/php52/pear')
Fatal error: Class 'calendarSuite' not found in /home/parkstee/public_html/forum/portal/block/mini_cal.php on line 51
Installation Question
Re: Installation Question
Check if you have uploaded all portal files to the correct place (keep the directory structure of the directory "root" of the package).
The error message is clear: the file is missing on your webserver.
