Install.php login
halfbreed
Install.php login
Post by halfbreed »
Boardlink: http://halfhentai.tk
Installed the files and code by the instructions
nothing
I installed the files going by the instrutions that were included. I had no problem putting in the new files and changing the code.
When I go to install.php to begin the installation it comes up
PInUp Error
You must be logged in as an admin.
Go to login
I go to login, and when I put my username and password in, it takes me to the main forum. If i'm already logged in, and I go to the install.php it comes up with the same thing, basically just putting me in a circle of logging in and not getting anywhere.
Ice
Re: Install.php login
Post by Ice »
Download this file and overwrite the install directory. download/file.php?id=130
