Verified edits and file locations for both editied and provided files
Under my ACP => .MOD tab my portal configuration settings have disappeared. I have installed a couple other mods since the portal was isntalled, but no new ones that use the .MOD page (phogle map does use it, and was installed long before this happened). The portal itself is still up and running as configured before the page disappeared. Where do I start to look for the problem? I have tried to verify all the edits and file locatoins, but nothing sticks out as incorrect/changed.
Portal setup in ACP => .MOD disappeared
Re: Portal setup in ACP => .MOD disappeared
Fixed. I had to go into the system => Administartor Control PAnel and readded the modules individually. All is back to normal. Not sure why they left in th efirst place.
