Using some blocks on the index
Moderator: Dyo
dragz
Boardlink: http://www.megalk.com
Not a problem
Hi there. Thanks for the great mod. I have a little question. Can I use the Recent block and
Latest global announcements blocks on the index page? Is it possible?
Thanks for your time
Not a problem
Re: Using some blocks on the index
Better to ask here.
dragz
What? I tried using in index_body.html but it didn't work. Look at my site now. I removed the right bar and it looks nice
Still couldn't figure out how to add the shoutbox
<!-- INCLUDE portal/block/recent.html -->-
Dyo
- Tester
you also have to include the scripts to fill the *html-template with some live.
This is only for recent, for every other block only use the script-include from portal.php.
If you want it on index you can include it in index.php at board-root. I think the best place should be after the include for the portalview-includes.
Just try it, and post the result, I didn't test it.
It also shpould work to add it in portalview-includes, but it will include on every page, so it's not a goog idea to do so.
Regards
Dyo
if ($portal_config['portal_recent'])
include($phpbb_root_path . 'portal/block/recent.'.$phpEx);
// Add for Portalview of complete Board
include($phpbb_root_path . 'portal/includes/portalview.' . $phpEx);
Regards
Dyo
Es gibt so viele schlaue Signaturtexte, nur mir fällt grade nix vernünftiges ein.
Da sieht man mal für wie wichtig ich eine Signatur halte, Fliegendreck auf dem Monitor ist wichtiger für mich.
In welcher Hinsicht überlasse ich der Phantasie des Lesers.
dragz
I didn't get it. Can you explain what to do step by step?
Thnaks
Thnaks
Dyo
- Tester
I did in in my demoboard as an example for you, but its only done for prosilver.
Open: index.php
find:
after add:
open style/prosilver/template/index_body.html
find:
before add:
activate the recentblock in acp
Open: index.php
find:
// this is added to use of recentblock in index
}open style/prosilver/template/index_body.html
find:
<!-- INCLUDE forumlist_body.html -->Code: Select all
<!-- INCLUDE portal/block/recent.html -->Es gibt so viele schlaue Signaturtexte, nur mir fällt grade nix vernünftiges ein.
dragz
I screwed up adding the mod mod_portalview and now I'm tring to fix it,
I'll post a secreenshot later. I wont give up cuz this is the best
dragz
Because I don't need the bar on the right hand side I didnt do the overall footer edits. As far as I know I have done everything correctly but the site looks like this
Dyo
- Tester
well, to do this, you also have to edit the footer cause of the endinmg tags of the tables.
So do the normal edits on the overall_footer.html and than remove everything between:
and
<!-- [+] right block area -->Code: Select all
<!-- [-] right block area -->Es gibt so viele schlaue Signaturtexte, nur mir fällt grade nix vernünftiges ein.
dragz
Sorry for being late to reply, Im supposed to study cuz my exam is on Sunday, I did as you said but there is still things wrong, I'm using the 3.0.4 and I couldn't find what is causing these problems,
1st thing, some fonts are too large
2nd, No footer in the portal, simply, the end of the page looks like this,
3rd Blocks are not aligned properly on the login page
Dyo
- Tester
Could you please add a user for me to your forum and send me the username and password?
I'de like to have a look at the html-sourcecode.
vova_ob
- phpBB.de User: vova_ob
- phpBB.com User: vova_ob
Hello,
I want make index page with recent block.
My style is subsilver type
But your method, is not work:
Give correct instruction for intagration resent block in index page.
Thank you
Help me!!Open: index.php
find:
after add:
find:
before add:
Thank you
Hi vova_ob,
For the subsilver2 You must still be done here:
open style/subsilver2/template/index_body.html
find:
before add:
find:
<!-- INCLUDE portal/block/recent.html -->V.G. archivar
