i can't see portal and i have 2 new tab in acp
supercriss
Post by supercriss »
Boardlink: http://www.estetiste.altervista.org
I updated version 3.0.2 of the forum to .0.3 but having previously installed another portal (carver) I had to uninstall it because it was in conflict.
I have benefited so to install your portal.
search here
I have the template based on subsilver2 so I followed the instructions for the subSilver but now I can't see not only the portal but I have two more tab in the acp: one is called mods and one is called portal
ot/ I ask you excuse for bad English
Re: i can't see portal and i have 2 new tab in acp
You need to upload the subsilver2 template files, included in the portal package, to your template path.
The ACP tabs:
You can remove the ACP tab named "portal" - this is the one left over from the canver portal.
supercriss
Kevin wrote:You need to upload the subsilver2 template files, included in the portal package, to your template path.
i did it, when i try to see the forum i see
Parse error: syntax error, unexpected $end in /membri/estetiste/phpBB2/cache/tpl_subsilver2_overall_header.html.php on line 184
Kevin wrote:The ACP tabs:
ehm...how i can do?
dragz
Post by dragz »
phpbb2?
One of your problems is this, Check it out
http://board3.de/viewtopic.php?f=10&t=1372#p9073
Btw how did you manage to get that 'bar' for guests? I have been looking for that, :D
supercriss
phpbb2?
was the old name of the forum when I upgraded from phpbb2 to phpbb3 I have not changed so as not to create problems
dragz wrote:One of your problems is this, Check it out
you can find the "bar" on phpbb.it
now i have uninstalled the portal :cry:
maybe i try again...maybe! but:
when i install i have to follow the directions in the install file or only those of subSilver?
I install and then edit the prosilver or not?
supercriss wrote:now i have uninstalled the portal
So no more help is needed?
This was an mistake you've made by editing the overall_header. Obviously a not correct set <!-- ENDIF -->
The not needed ACP tab could be removed in the ACP module management.
dragz
Post by dragz »
May be you can share the code with me cuz I dunno italian,
Hey bro, Dont give up things like that
supercriss
i'll try again to install portal.. if you help me ;)
i'm a sister :D
if you pm your email i'll send the code
Mousstik
Post by Mousstik »
I have the same problem.
If I understood well I must reverify the “overall_header”.
But my concern is that it is not subsilver which I have to modify because I do not use this topic. Do I have to modify this topic nevertheless?
here the code of my “overall_header” of my topic:
<li><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a></li>
it is it only line containing logout which there is in my file thus I cannot place the ENDIF elsewhere.
if somebody would have a solution. thank you in advance.
streak
Post by streak »
I also want to use the Subsilver2 template but I am getting the same error. It works fine with prosilver template. I have installed the subsilver and made the changes 3 times. I dont know what i am doing wrong here... But I am getting the same error when i try to go to the webstite with that template.
streak
Post by streak »
Here is what my overall_header.html look like.
I am geting this Error:
Parse error: syntax error, unexpected '}' in /home/content/s/t/r/streakin/html/cache/tpl_subsilver2_overall_header.html.php on line 196
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
	var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
	return false;
* Mark/unmark checklist
	if (!parent)
	if (!parent)
		return;
			rb[r].checked = state;
<!-- IF ._file -->
	function play_qt_file(obj)
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.Play();
</script>
</head>
<a name="top"></a>
<div id="wrapheader">
	<div id="logodesc">
        <div id="menubar">
			<td class="genmed">
				<!-- IF not S_IS_BOT --><a href="{U_LOGIN_LOGOUT}"><img src="{T_THEME_PATH}/images/icon_mini_login.gif" width="12" height="13" alt="*" /> {L_LOGIN_LOGOUT}</a>&nbsp;<!-- ENDIF -->
				<!-- IF U_RESTORE_PERMISSIONS --> &nbsp;<a href="{U_RESTORE_PERMISSIONS}"><img src="{T_THEME_PATH}/images/icon_mini_login.gif" width="12" height="13" alt="*" /> {L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
				<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> &nbsp;<span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
					<!-- IF S_USER_LOGGED_IN -->
						<!-- IF S_DISPLAY_PM --> &nbsp;<a href="{U_PRIVATEMSGS}"><img src="{T_THEME_PATH}/images/icon_mini_message.gif" width="12" height="13" alt="*" /> {PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a><!-- ENDIF -->
					<!-- ELSEIF S_REGISTER_ENABLED --> &nbsp;<a href="{U_REGISTER}"><img src="{T_THEME_PATH}/images/icon_mini_register.gif" width="12" height="13" alt="*" /> {L_REGISTER}</a>
			<td class="genmed" align="{S_CONTENT_FLOW_END}">
				<a href="{U_FAQ}"><img src="{T_THEME_PATH}/images/icon_mini_faq.gif" width="12" height="13" alt="*" /> {L_FAQ}</a>
				<!-- IF S_DISPLAY_SEARCH -->&nbsp; &nbsp;<a href="{U_SEARCH}"><img src="{T_THEME_PATH}/images/icon_mini_search.gif" width="12" height="13" alt="*" /> {L_SEARCH}</a><!-- ENDIF -->
					<!-- IF S_DISPLAY_MEMBERLIST -->&nbsp; &nbsp;<a href="{U_MEMBERLIST}"><img src="{T_THEME_PATH}/images/icon_mini_members.gif" width="12" height="13" alt="*" /> {L_MEMBERLIST}</a><!-- ENDIF -->
					<!-- IF S_USER_LOGGED_IN -->&nbsp; &nbsp;<a href="{U_PROFILE}"><img src="{T_THEME_PATH}/images/icon_mini_profile.gif" width="12" height="13" alt="*" /> {L_PROFILE}</a><!-- ENDIF -->
	<div id="datebar">
<div id="wrapcentre">
	<p class="searchbar">
	</p>
	<br style="clear: both;" />
Does anyone see anything wrong here? I am really lost. Thanks for your time in advance. Keep up the great work.
streak
Post by streak »
Fixed the problem.
<!-- ENDIF --> <!-- IF S_DISPLAY_SEARCH -->
Like stated above... I had a <!-- ENDIF --> on line 192 when it should not have been there. Problem solved. Hope this will help the rest of you.
What style do you use?
Try to delete this: <!-- ENDIF --> from line 196
EDIT: ah, that was it ;)
