hw
Re: Acid Tech???
Is Acid Tech subsilver or prosilverbased ?
Whats the Problem , you dont find the text to edit ?
Maybe ....
Maybe ....
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<td id="logorow" align="center"><div id="logo-left"><div id="logo-right">
<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>
</div></div></td>
Re: Acid Tech???
You will always have to do the subsilver2 changes for AcidTech. The following instructions were made for AcidTechTiger, but they should also work for any other version of AcidTech: http://www.board3-styles.de/downloads.p ... l&df_id=24
Re: Acid Tech???
In fact, they do. The navbar and some parts like the time info are removed in order to maintain a cleaner look for the portal. I think you probably don't need to be informed that you are on the portal while viewing the portal. Also the user menu has pretty much everything the navbar has. ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
