[RC] Portalview v1.0.0RC2
Moderator: Dyo
- phpBB.de User: Christian_N
- phpBB.com User: Christian_N
Re: [RC] Portalview v1.0.0RC2
Please download the MOD you down again, the files are all present.
There have been 100 users installed it and nobody did not find the file.
And it's also better to install it manually, it has not been tested on the AutoMod out, since both RC MODs still are.
Sorry Google-English *gg*
- phpBB.de User: wintstar
- phpBB.com User: wintstar
Ich komm nochml auf meine Anfrage vom 27.10. zurück
Fehlermeldung
Wäre prima wenn jemand eine Lösung hätte
Would be great if someone had a solution
Versuchs nochmal eine Antwort auf meine Frage. Hatt jemand eine Lösung wie der Gallerybloock in der Portalview eingebaut wird, so das die obige Fehlermeldung nicht kommt
The experiment again an answer to my question. Hatt someone a solution like the Gallerybloock plugs into the Portalview, so the above error message is not
Danke
Thanks
Stephan
Fehlermeldung
Parse error: syntax error, unexpected $end in C:\xampp\htdocs\cq\gallery\includes\functions_recent.php on line 344
Danke
Thanks
Stephan
Gruß Stephan
- Portal Enthusiast
Ill give it a try again.Christian_N wrote:Please download the MOD you down again, the files are all present.
Thanks for respons..
- Portal Enthusiast
I just downloaded the package again. I unzipped it.
Open the install.xml file:
It's say:
Included files
* root/portal/includes/portalview.php
But in the package I also find files like:
styles/prosilver/templates/portal/portal_footer.html
styles/prosilver/templates/portal/portal_header.html
What to do with them?
Open: styles/prosilver/template/portal/portal_body.html
FIND:
FIND:
OPEN:
Open: portal/block/search.php
FIND:
I hope you can help?
It's say:
Included files
FIND:
Replace with<table cellpadding="0" cellspacing="0" border="0" width="100%">
<!-- [+] left block area -->
<td valign="top" style="width: <!-- IF $S_COLUMNS_WIDTH_OVERRIDE -->{$PORTAL_LEFT_COLUMN_OVERRIDE}<!-- ELSE -->{PORTAL_LEFT_COLUMN}<!-- ENDIF -->px; padding-right:{$BLOCK_DISTANCE};">
<br style="clear:both" />
<!-- IF S_STYLE_OPTIONS and S_DISPLAY_CHANGE_STYLE -->
<!-- INCLUDE portal/block/change_style.html -->
<!-- INCLUDE portal/block/additional_blocks_left.html -->
<!-- IF S_DISPLAY_BIRTHDAY_LIST -->
<!-- INCLUDE portal/block/birthday_list.html -->
<!-- IF S_DISPLAY_CLOCK -->
<!-- INCLUDE portal/block/clock.html -->
<!-- IF S_DISPLAY_PORTALSEARCH and S_DISPLAY_SEARCH -->
<!-- INCLUDE portal/block/search.html -->
<!-- IF S_DISPLAY_RANDOM_MEMBER -->
<!-- INCLUDE portal/block/random_member.html -->
<!-- IF S_DISPLAY_ATTACHMENTS -->
<!-- INCLUDE portal/block/attachments.html -->
<!-- IF S_CUSTOM_SMALL -->
<!-- INCLUDE portal/block/custom_small.html -->
<!-- IF S_DISPLAY_TOP_POSTERS -->
<!-- INCLUDE portal/block/top_poster.html -->
<!-- IF S_DISPLAY_LATEST_MEMBERS -->
<!-- INCLUDE portal/block/latest_members.html -->
<!-- IF S_DISPLAY_LINK_US -->
<!-- INCLUDE portal/block/link_us.html -->
<!-- [-] left block area -->
<td valign="top">
With what? Is the part going to be deleted? Else somethings is missing...
FIND:
<!-- please keep this credits visible, thank you! -->
<!-- [-] center block area -->
<!-- [+] right block area -->
<td valign="top" style="width: <!-- IF $S_COLUMNS_WIDTH_OVERRIDE -->{$PORTAL_RIGHT_COLUMN_OVERRIDE}<!-- ELSE -->{PORTAL_RIGHT_COLUMN}<!-- ENDIF -->px; padding-left:{$BLOCK_DISTANCE};">
<!-- IF S_DISPLAY_USERMENU -->
<!-- INCLUDE portal/block/login_box.html -->
<!-- INCLUDE portal/block/user_menu.html -->
<!-- INCLUDE portal/block/additional_blocks_right.html -->
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN and S_ZEBRA_ENABLED and S_DISPLAY_FRIENDS -->
<!-- INCLUDE portal/block/online_friends.html -->
<!-- IF S_DISPLAY_ADVANCED_STAT -->
<!-- INCLUDE portal/block/statistics.html -->
<!-- IF S_DISPLAY_MINICAL -->
<!-- INCLUDE portal/block/mini_calendar.html -->
<!-- IF S_DISPLAY_LEADERS_EXT -->
<!-- INCLUDE portal/block/leaders_ext.html -->
<!-- ELSEIF S_DISPLAY_LEADERS -->
<!-- INCLUDE portal/block/leaders.html -->
<!-- IF S_DISPLAY_LAST_BOTS and S_LAST_VISITED_BOTS -->
<!-- INCLUDE portal/block/latest_bots.html -->
<!-- IF S_DISPLAY_LINKS -->
<!-- INCLUDE portal/block/links.html -->
<!-- IF S_DISPLAY_PAY_S -->
<!-- INCLUDE portal/block/donation_small.html -->
<!-- [-] right block area -->
<!--// board3 Portal by www.board3.de //-->
FIND:
'S_SEARCH_ACTION' => append_sid("{$phpbb_root_path}search.$phpEx"),
What is your problem?
1. I have the MOD by http://www.phpbb-projekt.de/downloads.p ... il&df_id=4 downloaded.
2. Did I unzipped that file.
3. All files are available, see screenshot:
When you comment, it still stands, what to do:
Please consider our Board3.de Rules.
Sorry, but here I must also warn you about repeated Topic-Bumping.install.xml wrote:Comments
There is no "replace-with"-code as you need to delete the code.
Board3 Rules wrote:
- Topic-Bumping is only accepted at least 24 hrs. after posting.
- Portal Enthusiast
Christian_N wrote: Sorry, but here I must also warn you about repeated Topic-Bumping.
I made a post:
Postby frold on Tue 10. Nov 2009, 22:19
I made a gentle bump:
by frold on Thu 12. Nov 2009, 14:44
Well I get it more then 24hours between the 2 posts. So I dont see the sense in that line...?
I havent said anything about missing files I said there is more files included in the package then mention in the install file.
Sry my english not very good, now I have understood it.
Please download the complete ROOT directory on your webspace.
The install.xml is fixed with the next version.
well im installing this and i have installed your mod countless times on diff styles and for some odd reason, when i install it on se_pro style it puts all my page's to a blank page. or makes the main portal page all distorted. i see i just missed you 42 mins ago, but if we can set up a time i can install it real fast and you can see the error's, i will not leave the error's up for any extended period of time, for i need to continue working on this webscript.
so if you use Aol Instant Msger, you can msg me here
AIM = Hazmatspade
i know im american and your english is not to strong but we ill manage
fyi Website = ironmog.org
AIM = Hazmatspade
- phpBB.de User: DDG
- phpBB.com User: DDG
installiere phpBB Version 3.0.6 -> OK
installiere Portal Version 1.0.4 -> OK
installiere Portalview Version 1.0.0RC2 -> Fehler:
portal.php wird noch angezeigt. index.php bringt fehler 500.
Habe etwas rumprobiert, dabei ist mir aufgefallen, das wenn ich die Änderung in der /includes/functions.php wieder raus nehme der Fehler 500 weg ist. Nur funktioniert dann natürlich der Portalview nicht. Ich vermute, das es in der phpBB 3.0.6 eine Änderung gab, die in Verbindung mit Portalview den Fehler verursacht. mit der 3.0.5 hatte ich das alles am laufen.
Bitte um Hilfe
Gruß Dirk
Bitte um Hilfe
Gruß Dirk
keiner eine Idee?
wie schon geschrieben mit phpBB 3.0.5 lief noch alles!
Hat sonst noch jemand das Problem?
Hoffe, mir kann jemand helfen, bin völlig ratlos.
Gruß Dirk
keiner eine Idee?
Gruß Dirk
- phpBB.de User: Glueckmacher
Versuche es mal mit dieser functions.php.
http://rapidshare.com/files/315525094/f ... s.php.html
Bin mir jetzt nicht mehr sicher, ob ich nicht irgendwas eingebaut habe, das dann einen Fehler bei Dir verursachen könnte, aber ein Versuch sollte es wert sein. Die 3 von Dir genannten Installationen habe ich jedenfalls auch.
Natürlich solltest Du Deine eigene Datei vorher sichern.
phpbb: 3.3.0
Style: Aero, prosilver, SoftBlue, Absolution
Portal: 2.1.0
Portal: 2.1.0
Versuch mißglückt
da hatte ich sogar auf der Portal.php schon den fehler 500
Trotzdem danke fürs versuchen
Gruß Dirk
Versuch mißglückt
Gruß Dirk
I have just tried to download, and install.
As mentioned in an earlier post, the install.xml replacement information is blank for a few of the replacements. Is there a download link to the new version of the install.xml, or an old version that works with phpbb3 3.0.6, board3 1.0.4, etc?
If it is blank you probably have to replace it with a blank.
Da offensichtlich keiner das gleiche Problem hat wie ich, habe ich hier mal den link zu meine functions.php
http://www.ls-modfabrik.de/functions.txt
Vielleicht sieht ja jemand den Fehler. (der Teil der Probleme macht ist Auskommentiert: Zeile 4426-4429)
Gruß Dirk
Gruß Dirk
