[RC] Portalview v1.0.0RC2
Moderator: Dyo
Addon: Portalview
Addon-Version: [REL] 1.0.0RC2
Addon-Description:
Portalview like Board3 for your phpBB3.
Addon-Requirements: board3 Portal v1.0.4 (to download)
Addon-Authors: Christian_N
Addon-Download: Download Block v1.0.0RC2
phpBB-Version: 3.0.5
phpBB-Styles: prosilver, subsilver2
BugTracker: http://www.phpbb-projekt.de/tracker.php?p=3
Please don't upload the mod anywhere (to offer it as a download), without asking me before, thanks.
Reason: release 1.0.0RC2
Re: MOD Portalview RC1
Demo: ** Link entfernt **
Reason: Link entfernt, das Forum ist voll mit Spam
dragz
Post by dragz »
Thanks. I need this so bad :D
Jemme
phpBB.com User: Jemme
Post by Jemme »
I just installed this mod and it works nicely with one exception. On the portal page I don't have the blocks on the right anymore... How do I get those back?
FYI, the board is here: http://www.mx-5club.be/forum
Dyo
Tester
Post by Dyo »
You have an error relatet to the poll-block.
Have a look at all changes made relatet to this block and the scripts, maybe a copypaste-error or so mething else.
regards
dyo
Es gibt so viele schlaue Signaturtexte, nur mir fällt grade nix vernünftiges ein.
Da sieht man mal für wie wichtig ich eine Signatur halte, Fliegendreck auf dem Monitor ist wichtiger für mich.
In welcher Hinsicht überlasse ich der Phantasie des Lesers.
Fieke
phpBB.de User: Fieke
phpBB.com User: Fieke
Post by Fieke »
I do have the same error, no right blocks and I have checked several times if I have copied and pasted right, cannot find mistakes regarding that.
Parse error: syntax error, unexpected $end in /home/dscrapping/domains/digitalscrapping.eu/public_html/forum2/cache/tpl_prosilver_portal.block.poll.html.php on line 64
When I delete the file tpl_prosilver_portal.block.poll.html.php through FTP and I refresh the portal page, I DO have the right blocks...but when I then refresh again, they are gone again.
So somehow it works OK - but there is a flaw somewhere. How else can it be possible for me to sometimes have the blocks show up, and after refreshing I see they're gone again. I doubt this could be a copy/paste error, because in that case they would NEVER show up.
Could you please help me figuring out how to solve this? Thanks in advance for your time!
Kind regards,
Fieke
Fieke
Post by Fieke »
I have found the "problem" - in your install.xml there is a small mistake. See the post below,
viewtopic.php?f=31&t=1355
where you state the following:
open portal/block/poll.php
find:
          'S_HAS_POLL' => $has_poll,
replace with:
          'S_PORTAL_HAS_POLL' => $has_poll,
open styles/prosilver/template/portal/block/poll.html
find:
       <!-- IF S_HAS_POLL -->
***replace with:***
       <!-- IF S_PORTAL_HAS_POLL -->
whereas in your actual install.xml that is in the download, you state the following:
Open: styles/prosilver/template/portal/block/poll.html
Code:Select All
***Add after***
Code:Select All
I have now used replace instead of add after, and my blocks are back again and don't go away anymore after I refresh the page.
Hopefully this helps others who have bumped into the same problem. You might want to change that line in the install.xml ;)
Kind regards,
Fieke
Dyo
Tester
Post by Dyo »
Many Thanks, to figure out the error.
It will be changed in the release 1.0.0.
The release will come online the next few weeks.
Regards
Dyo
everton1995
Post by everton1995 »
I still get the same problem after replacing the lines instead of adding....
Can someone post a working poll.php & a working poll.html please...........
Dyo
Tester
Post by Dyo »
Sorry, but I don't have these files without a lot of other changes at the moment.
Please have a look at poll.php if there is the same error as described in poll.html
Tomoroow I'll set up a new board with this MOD so than I can tell you if there is a bug.
Regards
Dyo
everton1995
This is my poll.php
* @package - Board3portal
* @version $Id: poll.php 358 2008-08-31 18:22:03Z kevin74 $
if (!defined('IN_PHPBB') or !defined('IN_PORTAL'))
	die('Hacking attempt');
	exit;
* @ignore
$user->add_lang('viewtopic');
$view = request_var('view', '');
$update = request_var('update', false);
$poll_view = request_var('polls', '');
$poll_view_ar = ( strpos(urldecode($poll_view), ',') !== FALSE ) ? explode(',', urldecode($poll_view)) : (($poll_view != '') ? array($poll_view) : array());
if ($update && $portal_config['portal_poll_allow_vote'])
	$up_topic_id = request_var('t', 0);
	$up_forum_id = request_var('f', 0);
	$voted_id = request_var('vote_id', array('' => 0));
	$cur_voted_id = array();
		$sql = 'SELECT poll_option_id
			FROM ' . POLL_VOTES_TABLE . '
			WHERE topic_id = ' . $up_topic_id . '
				AND vote_user_id = ' . $user->data['user_id'];
			$cur_voted_id[] = $row['poll_option_id'];
		$db->sql_freeresult($result);
		// Cookie based guest tracking ... I don't like this but hum ho
		// it's oft requested. This relies on "nice" users who don't feel
		// the need to delete cookies to mess with results.
		if (isset($_COOKIE[$config['cookie_name'] . '_poll_' . $up_topic_id]))
			$cur_voted_id = explode(',', $_COOKIE[$config['cookie_name'] . '_poll_' . $up_topic_id]);
			$cur_voted_id = array_map('intval', $cur_voted_id);
	$sql = 'SELECT t.poll_length, t.poll_start, t.poll_vote_change, t.topic_status, f.forum_status, t.poll_max_options
			FROM ' . TOPICS_TABLE . ' t, ' . FORUMS_TABLE . " f
			WHERE t.forum_id = f.forum_id AND t.topic_id = " . (int) $up_topic_id . " AND t.forum_id = " . (int) $up_forum_id;
	$topic_data = $db->sql_fetchrow($result);
	$s_can_up_vote = (((!sizeof($cur_voted_id) && $auth->acl_get('f_vote', $up_forum_id)) ||
		($auth->acl_get('f_votechg', $up_forum_id) && $topic_data['poll_vote_change'])) &&
		(($topic_data['poll_length'] != 0 && $topic_data['poll_start'] + $topic_data['poll_length'] > time()) || $topic_data['poll_length'] == 0) &&
		$topic_data['topic_status'] != ITEM_LOCKED &&
		$topic_data['forum_status'] != ITEM_LOCKED) ? true : false;
	if( $s_can_up_vote )
		if (!sizeof($voted_id) || sizeof($voted_id) > $topic_data['poll_max_options'] || in_array(VOTE_CONVERTED, $cur_voted_id))
			$redirect_url = append_sid("./portal.$phpEx");
			meta_refresh(5, $redirect_url);
			if (!sizeof($voted_id))
				$message = 'NO_VOTE_OPTION';
			else if (sizeof($voted_id) > $topic_data['poll_max_options'])
				$message = 'TOO_MANY_VOTE_OPTIONS';
				$message = 'VOTE_CONVERTED';
			$message = $user->lang[$message] . '<br /><br />' . sprintf($user->lang['RETURN_PORTAL'], '<a href="' . $redirect_url . '">', '</a>');
			trigger_error($message);
		foreach ($voted_id as $option)
			if (in_array($option, $cur_voted_id))
				continue;
			$sql = 'UPDATE ' . POLL_OPTIONS_TABLE . '
				SET poll_option_total = poll_option_total + 1
				WHERE poll_option_id = ' . (int) $option . '
					AND topic_id = ' . (int) $up_topic_id;
				$sql_ary = array(
					'topic_id'			=> (int) $up_topic_id,
					'poll_option_id'	=> (int) $option,
					'vote_user_id'		=> (int) $user->data['user_id'],
					'vote_user_ip'		=> (string) $user->ip,
				$sql = 'INSERT INTO ' . POLL_VOTES_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary);
		foreach ($cur_voted_id as $option)
			if (!in_array($option, $voted_id))
					SET poll_option_total = poll_option_total - 1
					$sql = 'DELETE FROM ' . POLL_VOTES_TABLE . '
						WHERE topic_id = ' . (int) $up_topic_id . '
							AND poll_option_id = ' . (int) $option . '
							AND vote_user_id = ' . (int) $user->data['user_id'];
		if ($user->data['user_id'] == ANONYMOUS && !$user->data['is_bot'])
			$user->set_cookie('poll_' . $up_topic_id, implode(',', $voted_id), time() + 31536000);
		$sql = 'UPDATE ' . TOPICS_TABLE . '
			SET poll_last_vote = ' . time() . "
			WHERE topic_id = $up_topic_id";
		//, topic_last_post_time = ' . time() . " -- for bumping topics with new votes, ignore for now
		trigger_error($user->lang['VOTE_SUBMITTED'] . '<br /><br />' . sprintf($user->lang['RETURN_PORTAL'], '<a href="' . $redirect_url . '">', '</a>'));
$where = '';
$poll_forums = false;
if( $portal_config['portal_poll_topic_id'] !== '' )
	$poll_forums_config  = explode(',' ,$portal_config['portal_poll_topic_id']);
	foreach($poll_forums_config as $poll_forum )
		if ( is_numeric(trim($poll_forum)) === TRUE )
			$poll_forum = (int) trim($poll_forum);
			if( $auth->acl_get('f_read', $poll_forum) )
				$poll_forums = true;
				$where .= ($where == "") ? "t.forum_id = '{$poll_forum}'" : " OR t.forum_id = '{$poll_forum}'";
	$forum_list = $auth->acl_getf('f_read', true);
	foreach($forum_list as $pf => $pf_data )
		$pf = (int) trim($pf);
		$where .= ($where == "") ? "t.forum_id = '{$pf}'" : " OR t.forum_id = '{$pf}'";
$where = ($where !== '') ? "AND ({$where})" : '';
if( $poll_forums === TRUE )
	$sql = 'SELECT t.poll_title, t.poll_start, t.topic_id,  t.topic_first_post_id, t.forum_id, t.poll_length, t.poll_vote_change, t.poll_max_options, t.topic_status, f.forum_status, p.bbcode_bitfield, p.bbcode_uid
			FROM ' . TOPICS_TABLE . ' t, ' . POSTS_TABLE . ' p, ' . FORUMS_TABLE . " f
			WHERE t.forum_id = f.forum_id AND t.topic_approved = 1 AND t.poll_start > 0
			{$where}
			AND t.topic_moved_id = 0
			AND p.post_id = t.topic_first_post_id
			ORDER BY t.poll_start DESC";
	$limit = ( isset($portal_config['portal_poll_limit']) ) ? $portal_config['portal_poll_limit'] : 3;
	$result = $db->sql_query_limit($sql, $limit);
	$has_poll = false;
	if ($result)
		while( $data = $db->sql_fetchrow($result) )
			$has_poll = true;
			$poll_has_options = false;
			$topic_id = (int) $data['topic_id'];
			$forum_id = (int) $data['forum_id'];
			if( $portal_config['portal_poll_allow_vote'] )
					$vote_sql = 'SELECT poll_option_id
						WHERE topic_id = ' . $topic_id . '
					$vote_result = $db->sql_query($vote_sql);
					while ($row = $db->sql_fetchrow($vote_result))
					$db->sql_freeresult($vote_result);
					if (isset($_COOKIE[$config['cookie_name'] . '_poll_' . $topic_id]))
						$cur_voted_id = explode(',', $_COOKIE[$config['cookie_name'] . '_poll_' . $topic_id]);
				$s_can_vote = (((!sizeof($cur_voted_id) && $auth->acl_get('f_vote', $forum_id)) ||
					($auth->acl_get('f_votechg', $forum_id) && $data['poll_vote_change'])) &&
					(($data['poll_length'] != 0 && $data['poll_start'] + $data['poll_length'] > time()) || $data['poll_length'] == 0) &&
					$data['topic_status'] != ITEM_LOCKED &&
					$data['forum_status'] != ITEM_LOCKED) ? true : false;
			} else {
				$s_can_vote = false;
			$s_display_results = ( !$s_can_vote || ( $s_can_vote && sizeof($cur_voted_id) ) || ( $view == 'viewpoll' && in_array($topic_id, $poll_view_ar) ) ) ? true : false;
			$poll_sql = 'SELECT po.poll_option_id, po.poll_option_text, po.poll_option_total
				FROM ' . POLL_OPTIONS_TABLE . " po
				WHERE po.topic_id = {$topic_id}
				ORDER BY po.poll_option_id";
			$poll_result = $db->sql_query($poll_sql);
			$poll_total_votes = 0;
			$poll_data = array();
			if ($poll_result)
				while( $polls_data = $db->sql_fetchrow($poll_result) )
					$poll_has_options = true;
					$poll_data[] = $polls_data;
					$poll_total_votes += $polls_data['poll_option_total'];
			$db->sql_freeresult($poll_result);
			$make_poll_view = array();
			if( in_array($topic_id, $poll_view_ar) === FALSE )
				$make_poll_view[] = $topic_id;
				$make_poll_view = array_merge($poll_view_ar, $make_poll_view);
			$poll_view_str = urlencode( implode(',', $make_poll_view) );
			$portalpoll_url= append_sid("./portal.$phpEx", "polls=$poll_view_str");
			$portalvote_url= append_sid("./portal.$phpEx", "f=$forum_id&t=$topic_id");
			$viewtopic_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id");
			$poll_end = $data['poll_length'] + $data['poll_start'];
// Parse BBCode title
			if ($data['bbcode_bitfield'])
				$poll_bbcode = new bbcode();
				$poll_bbcode = false;
			$data['poll_title'] = censor_text($data['poll_title']);
			if ($poll_bbcode !== false)
				$poll_bbcode->bbcode_second_pass($data['poll_title'], $data['bbcode_uid'], $data['bbcode_bitfield']);
			$data['poll_title'] = bbcode_nl2br($data['poll_title']);
			$data['poll_title'] = smiley_text($data['poll_title']);
			unset($poll_bbcode);
			$template->assign_block_vars('poll', array(
				'S_POLL_HAS_OPTIONS' => $poll_has_options,
				'POLL_QUESTION' => $data['poll_title'],
				'U_POLL_TOPIC' => append_sid($phpbb_root_path . 'viewtopic.' . $phpEx . '?t=' . $topic_id . '&f=' . $forum_id),
				'POLL_LENGTH' => $data['poll_length'],
				'TOPIC_ID' => $topic_id,
				'TOTAL_VOTES' 		=> $poll_total_votes,
				'L_MAX_VOTES'		=> ($data['poll_max_options'] == 1) ? $user->lang['MAX_OPTION_SELECT'] : sprintf($user->lang['MAX_OPTIONS_SELECT'], $data['poll_max_options']),
				'L_POLL_LENGTH'		=> ($data['poll_length']) ? sprintf($user->lang[($poll_end > time()) ? 'POLL_RUN_TILL' : 'POLL_ENDED_AT'], $user->format_date($poll_end)) : '',
				'S_CAN_VOTE'		=> $s_can_vote,
				'S_DISPLAY_RESULTS'	=> $s_display_results,
				'S_IS_MULTI_CHOICE'	=> ($data['poll_max_options'] > 1) ? true : false,
				'S_POLL_ACTION'		=> $portalvote_url,
				'U_VIEW_RESULTS'   => $portalpoll_url . '&view=viewpoll#viewpoll',
				'U_VIEW_TOPIC'		=> $viewtopic_url
			foreach($poll_data as $pd)
				$option_pct = ($poll_total_votes > 0) ? $pd['poll_option_total'] / $poll_total_votes : 0;
				$option_pct_txt = sprintf("%.1d%%", ($option_pct * 100));
			// Parse BBCode option text
			$pd['poll_option_text'] = censor_text($pd['poll_option_text']);
				$poll_bbcode->bbcode_second_pass($pd['poll_option_text'], $data['bbcode_uid'], $data['bbcode_bitfield']);
			$pd['poll_option_text'] = bbcode_nl2br($pd['poll_option_text']);
			$pd['poll_option_text'] = smiley_text($pd['poll_option_text']);
				$template->assign_block_vars('poll.poll_option', array(
					'POLL_OPTION_ID' 		=> $pd['poll_option_id'],
					'POLL_OPTION_CAPTION' 	=> $pd['poll_option_text'],
					'POLL_OPTION_RESULT' 	=> $pd['poll_option_total'],
					'POLL_OPTION_PERCENT' 	=> $option_pct_txt,
					'POLL_OPTION_PCT'		=> round($option_pct * 100),
					'POLL_OPTION_IMG' 		=> $user->img('poll_center', $option_pct_txt, round($option_pct * 250)),
					'POLL_OPTION_VOTED'		=> (in_array($pd['poll_option_id'], $cur_voted_id)) ? true : false
	$template->assign_vars(array(
		'S_DISPLAY_POLL' => true,
		'POLL_LEFT_CAP_IMG'	=> $user->img('poll_left'),
		'POLL_RIGHT_CAP_IMG'=> $user->img('poll_right'),
As you can see 'S_PORTAL_HAS_POLL' => $has_poll, has replaced <!-- IF S_HAS_POLL -->
...........and this is my poll.html which also has the edit.
(SECTION)
<!--version $Id: poll.html 358 2008-08-31 18:22:03Z kevin74 $ //-->
<a name="viewpoll"></a>
<div class="forabg"><span class="corners-top"><span></span></span>
	<ul class="topiclist">
		<li class="header"><dl><dt>{L_POLL}</dt></dl></li>
	<div class="panel">
		<div class="inner">
		<!-- BEGIN poll -->
Im not sure whats happening but I still nave no right side blocks, and only 1 or two on the left...........any ideas?
Silkdream
phpBB.de User: Silkdream
phpBB.com User: Silkdream
Post by Silkdream »
Mod eingebaut aber sieht grausig aus wie bekommt man den Forumsteil wieder auf Normale Größe, zur Zeit wird das Forum gestaucht wenn die Boxen Links und Rechts sind?
everton1995
Silkdream wrote:Hallo
amroth
Post by amroth »
Funzt diese Mod auch bei WoWMoonclaw ?
Oder wie kann ich sie bei WoWMoonclaw einbinden?
www.religions-of-azeroth.de
< Wir Suchen GM's | Scripter / Bugfixxer | Foren Moderatoren | Foren Designer >
derkubi
Portal Enthusiast
Post by derkubi »
Habe auch einen Fehler in einem neuen Testboard :
Im Portal sieht alles normal aus , klicke ich aber z.B. auf ein Forum dann fehlen Blocks teilweise wie Calendarblock On Portal
oder ganz wie Custom Small Block (das Youtubevideo )
Im Portal
http://derkubi.de.funpic.de/bilder/fehlerpv1.gif
Anzeige von Beiträgen
http://derkubi.de.funpic.de/bilder/fehlerpv2.gif
