Your Portal Version: 1.0.2
Is there any way to put blocks in one side (left or right) in index.php?
block in index.php
Re: block in index.php
You can't do this using board3 portal but have a look at this,
http://www.startrekguide.com/community/ ... 153#p70153
thanks pal.
Erm, Dyo has his own forum for this: viewforum.php?f=31
Come on, It was before you start that section, credit goes to Dyo
Hä?
Whats your problem?
Whats your problem?
I tried this MOD (silverbar) but have a problemYou can't do this using board3 portal but have a look at this,
Silverbar is also showing in portal page, that means I have 3 side blocks now there
The 2 from portal and one from silver bar.
as I understand I can NOT remove it from portal.php cause it is loading in overall_header.
Is there a possibility to put something like <IF> in overall_header to prevent loading in portal.php??
thanks in advance
