Your Portal Version: 1.0.2
Boardlink: http://www.megalk.com
This menu looks great. How can I make my main menu look like this? I tried but only thing I could do myself is removing the thin black outline. Can anyone help me?
Im sure you guyz will add a nice user menu in the next version.
-Thanks-
Customizing the main menu
Re: Customizing the main menu
You will have to modify the portal.css and some images in the /theme/portal/images/ folder of your style. You can find a little help here: viewtopic.php?f=24&t=917
