SQL error on install
Myaj
Post by Myaj »
Your Portal Version: 1.0.2
Boardlink: http://www.hoofprintsacrosswi.com/forum
PHP Version: phpbb3
Followed install instructions
Re-tried install 3 times, searched forums, tried both 1.0.1 and 1.0.2 installs AND the "alternative install" I found in another thread with the same error. Purged cache.
Well, same problem everyone else is having from what it looks like on the forum.
I've tried checking and rechecking, completely restoring files to pre-mod and starting over, starting over with the different install.
No matter what I do, when I go to run the forum/install_portal/install.php I get this error:
General Error
SQL ERROR [ mysql4 ]
Table 'hoofprin_hoofprinphpBB3.phpbb_portal_config' doesn't exist [1146]
SQL
SELECT config_value as version FROM phpbb_portal_config WHERE config_name = 'portal_version' LIMIT 1
BACKTRACE
FILE: includes/db/mysql.php
LINE: 133
CALL: dbal_mysql->sql_error()
LINE: 180
CALL: dbal_mysql->sql_query()
FILE: includes/db/dbal.php
LINE: 145
CALL: dbal_mysql->_sql_query_limit()
FILE: install_portal/install.php
LINE: 51
CALL: dbal_mysql->sql_query_limit()
Any help would be greatly appreciated, as my board is pretty much stuck here until I get this working and I still have a lot of work to do! :)[/i]
Ice
Re: SQL error on install
Post by Ice »
Hmm, the error should be suppressed but obviously it is not. I'll see what I can come up with.
For the mean time, open install.php and delete:
			FROM ' . PORTAL_CONFIG_TABLE . "
			WHERE config_name = 'portal_version'";
	$result = @$db->sql_query_limit( $sql, 1 );
	$version = $db->sql_fetchrow( $result );
	if( sizeof( $version ) )
		$old_version = strtolower($version['version']);
		$db->sql_freeresult( $result );
		$sql = 'SELECT config_value as version
				FROM ' . CONFIG_TABLE . "
			$phpbb3portal = true;
			$old_version = ( strtolower($version['version']) == '1.1.0.b' ) ? '1.1.0b' : strtolower($version['version']) ;
Myaj
Post by Myaj »
I'm starting with this:
$old_version = 0;
	$phpbb3portal = false;
	$installed = $updated = $uninstalled =false;
When I delete what you stated above I have this:
$old_version = 0;
Which gives me this error:
Parse error: syntax error, unexpected T_ELSE in /home/hoofprin/public_html/forum/install_portal/install.php on line 48
I tried deleting that else followed by the {, but that just gave me an error farther down the page. I don't know enough about the code to guess anymore at what to do?
Myaj
Post by Myaj »
Dang, and now my entire board is giving that error about the missing table.. not just when I run the install.
Ice
Post by Ice »
Hmm half the code I posted cut off, what I meant to say was that you need to delete:
Myaj
Post by Myaj »
I was hoping it was as simple as it getting cut off :)
Thank you I'll try that edit and let you know if it works.
Myaj
Post by Myaj »
Okay, that allowed me to run the installer, which looked perfect, then I deleted the install_portal folder.
Now I'm getting this error:
Fatal error: Call to undefined function: bbcode_nl2br() in /home/hoofprin/public_html/forum/portal/block/poll.php on line 323
Ice
Post by Ice »
Strange as that function comes from the functions.php that should have been included already.
At the top of portal.php check there is the line
include($phpbb_root_path . 'portal/includes/functions.'.$phpEx);
Myaj
Post by Myaj »
Yes, it is there:
define('IN_PHPBB', true);
define('IN_PORTAL', true);
For what its worth, the portal page came up perfect after the install... just with the note to delete the install folder. As soon as I deleted the install though, no more portal.
Myaj
Post by Myaj »
Do you think if I backup to a different version it might work?
