Bug in attachment module
Current Version: 2.3.0
Released: 2023-03-19
playagiron
Post by playagiron »
the portal looks great.
However I get a bug in the attachment modules, whenever I select OR only specific forums or specific extensions to show.
The SQL command to subset these seems to generate wrong SQL code, and I can see it as it somehow adds / around ' signs.
SELECT a.*, t.forum_id FROM phpbb_attachments a, phpbb_topics t WHERE a.topic_id <> 0 AND a.topic_id = t.topic_id AND t.forum_id IN (\'5\', \'15\', \'32\', \'33\', \'14\', \'31\', \'30\') AND a.extension = \'mp3\' ORDER BY filetime DESC, post_msg_id ASC LIMIT 2
My board runs on PHP 7.4 so dhousl be compatible no?
Re: Bug in attachment module
Open the File ./ext/board3/portal/modules/attachments.php
Find:
						' . $this->db->sql_escape($where) . '
Replace with:
						' . $where . '
playagiron
Perfect solution,
thanks a lot Udo!
Return to “Board3 Portal 2.3.x - English Support”
