Time zone set to index also show on portal
Current Version: 2.3.0
Released: 2023-03-19
bennybernaer
phpBB.de User: /
phpBB.com User: bennybernaer
Post by bennybernaer »
I would like to show the time setting shown at the top of the index page also above the portal.
Is this somehow possible ?
Thank you in advance!
bennybernaer
phpBB.de User: /
Re: Time zone set to index also show on portal
Open: portal_body.html
search:
{% INCLUDE 'overall_header.html' %}
{% INCLUDE 'portal/_block_config.html' %}
post below:
<p class="{S_CONTENT_FLOW_END} responsive-center time<!-- IF S_USER_LOGGED_IN --> rightside<!-- ENDIF -->"><!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<!-- ELSE -->{CURRENT_TIME}<!-- ENDIF --></p>
<!-- IF S_USER_LOGGED_IN --><p class="responsive-center time">{CURRENT_TIME}</p><!-- ENDIF -->
Am I right ?
It certainly works.
bennybernaer wrote: 2. December 2023 22:29 Open: portal_body.html
search:
The code can be found in root/ext/board3/portal/styles/prosilver/template/portal/portal_body.html.
bennybernaer wrote: 2. December 2023 22:29 post below:
The code can be found in root/styles/prosilver/template/index_body.html.
I tested it once and if you like it that way you can do it that way.
Return to “Board3 Portal 2.3.x - English Support”
