Changing the Latest News Block
dv-design
Post by dv-design »
Your Portal Version: 1.0.2RC3
Boardlink: http://dv-efs.com/portal.php
PHP Version: 5
The far right column will not fit in. Is it possible to exclude the Blue arrow images (or any forum icon) from this box, but maintain them within my forums?
If the above is not possible how to i simply make the center column wider? I saw how to make the right and left column wider but i could not find the option for this for the center column.
Any help would be great, thanks.
Re: Changing the Latest News Block
You have an ACP option (news + announcements) to disable the last two columns for thin styles, check it out, that will solve your problem.
JohnnyBoy928
phpBB.com User: Johnnyboy928
Post by JohnnyBoy928 »
Hey kevin where in Phpbb 3 can this be found in the ACP?? I looked all around... Thanks in advance
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Post by thomas.d »
You'll find it in the Board3 Portal settings in the MODS section of your ACP.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
JohnnyBoy928
yeah found it that night and it worked perfect... thanks...
