Remove portal modules from forum page
Demonloadz
phpBB.de User: Demonloadz
phpBB.com User: Demonloadz
Post by Demonloadz »
Hey all
Im trying to remove some portal modules from my forum index page as i have portal set to my main page but dont want them on my forum index page
Re: Remove portal modules from forum page
Go to ACP/Extensions/Portal Modules and move or delete the desired modules there.
Demonloadz
hi yes but that will remove them from my main portal page which is set to my home page i dont want that i want to remove them from my forum page which is a different page i only want to see thee portal modules i want to see on that page but not all of them if that makes sense im trying to find the div code in the files
What you want is not possible.
