Your Portal Version: 1.2
Boardlink: http://maxxforum.co.nr
I don't want my staff to be on the top posters list. Can anyone help me to remove them from the top list?
Remove Staff From Top Posters List
Re: Remove Staff From Top Posters List
Quick & dirty, not tested:
Open portal/block/top_posters.php
Search:
replace with:
You need to set the correct group ID, which you want to exclude in
AND group_id != 3
(in this example = 3)
You can add more lines like this, for each group you want to exclude.
Search:
$sql = 'SELECT user_id, username, user_posts, user_colour
FROM ' . USERS_TABLE . '
WHERE user_type <> ' . USER_IGNORE . '
AND user_posts <> 0
ORDER BY user_posts DESC';
$result = $db->sql_query_limit($sql, $portal_config['portal_max_most_poster']);
AND user_posts <> 0
AND group_id != 3
AND group_id != 3
Thanks a lot, I'll try
I tried making this change and i still show up in this box. How can i find out what group numbers correspond to which group?
Me too have the same above question. How can I find the group id?
Point on a link to the group.
E.g. memberlist.php?mode=group&g=9 is the link to our testgroup.
mode=group&g=9 <-- this is the group ID.
