errors at portal
Jeffrey Kroonenberg
errors at portal
Post by Jeffrey Kroonenberg »
I get an error:
AJAX error
Something went wrong with the request and the server returned an invalid response.
and at the top of the tabblat extensions I get an error.
[phpBB Debug] PHP Warning: in file [ROOT]/ext/board3/portal/acp/portal_module.php on line 128: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"?
[phpBB Debug] PHP Warning: in file [ROOT]/ext/board3/portal/acp/portal_module.php on line 448: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"?
and get this erro on the portal itself (front end)
[phpBB Debug] PHP Warning: in file [ROOT]/ext/board3/portal/portal/fetch_posts.php on line 137: A non-numeric value encountered
Otherwise, it works normally
He does not only adjust with the blocks
and this error
Uitzondering: The file
"/home/u54507p51835/domains/phpbbbase.nl/public_html/ext/board3/portal/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 12 (near "- @board3.portal.columns").
#0 /home/u54507p51835/domains/phpbbbase.nl/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/u54507p51...')
#1 /home/u54507p51835/domains/phpbbbase.nl/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/u54507p51835/domains/phpbbbase.nl/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/u54507p51835/domains/phpbbbase.nl/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/u54507p51835/domains/phpbbbase.nl/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/u54507p51835/domains/phpbbbase.nl/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/u54507p51835/domains/phpbbbase.nl/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/u54507p51835/domains/phpbbbase.nl/public_html/phpbb/di/container_builder.php(212): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/u54507p51835/domains/phpbbbase.nl/public_html/common.php(115): phpbb\di\container_builder->get_container()
#9 /home/u54507p51835/domains/phpbbbase.nl/public_html/adm/index.php(23): require('/home/u54507p51...')
#10 {main}
Re: errors at portal
There is an adapted version, link in my signature.
