Does it work with phpbb 3.3
justint
Post by justint »
I have just installed phpbb 3.3, and the portal is turned off. Am I safe to switch it on?
Re: Does it work with phpbb 3.3
Did you install the portal correctly?
justint
Post by justint »
Yes. I have been using it fine for about 10 years. But it doesn't seem to want to work with 3.3
There is an adapted version for 3.3, see link in my signature.
justint
Post by justint »
Thank you
