Using PHP
Lammerts
Using PHP
Post by Lammerts »
Hello,
I am creating my own module
Therefor I followed the instructions from the knowledge base (https://github.com/board3/Board3-Portal ... rtal-2.1.x)
All is setup and working :-)
But it seems I can't use php coding in the module.
Am I doing something wrong?
How can I use php when creating my own module?
Thank you
Lammerts
Re: Using PHP
Post by Lammerts »
Oh, almost 1k views but no one who can give me a little help?
I know I should use ***_side.php extension, but even that doesn't help me.
Maybe some have other ideas?
Re: Using PHP
What have you entered where?
Lammerts
Re: Using PHP
Post by Lammerts »
Thank you for the reply
In my main file I have the line
return '@lammert_daservermonitor/lammert_da_servermonitor_side.php';
I have the file called "lammert_da_servermonitor_side.php" in the folder .\phpBB3\ext\lammert\daservermonitor\styles\Hexagon\template.
The code in the file:
<?php echo "Hello"; ?>
In the block on the frontpage
is displayed, so I think the file is in the correct location and the file is called into the block.
Re: Using PHP
What do you want to display in this module?
Lammerts
Re: Using PHP
Post by Lammerts »
I try to create some custom modules for our Wolfenstein:ET community.
Some info about the server, the map plying and players on server.
The code is ready and the info is in a file I made: Here
The info is from een opensource (ET Splatterladder
This needs to be in a module on our community site: Here
When this is done, I want to create a module with names of the admins, which needs to be editable by admins.
But have not worked on that one yet.
Re: Using PHP
How to put something like this into a module, I'll have to pass.
Lammerts
Re: Using PHP
Post by Lammerts »
Thank you for your time and effort :-)
To me it looks like the module can handle HTML, but not PHP.
Maybe someone can answer this?
If it is possible to use PHP in a module, then I wonder how it can be done.
Maybe someone knows this?
To me it feels like a rather simple question, but somehow it is not.
Maybe anyone knows why?
Lammerts
Re: Using PHP
Post by Lammerts »
Seems no one knows how this module works.
Please close topic
dueller
Re: Using PHP
Post by dueller »
I also tried to use php and it gets commented out.
In the above example the line <?php echo "Hello"; ?> it gets commented and so it doesn't produce the "Hello" message, but only "Hi" that is printed with html code.
Did I miss something?
dueller
Re: Using PHP
Post by dueller »
Lammerts wrote: 27. May 2020 18:06 Thank you for the reply
At last I figured it out.
In the above example you have to give your file the html extension, lammert_da_servermonitor_side.html (php extension does nothing more).
Then you can't use php in it BUT INSTEAD OF IT YOU MUST USE twig template engine.
So instead of <?php echo "Hello"; ?> (that gets commented out) you MUST USE the equivalent {{ "Hello" }}
Such a basic thing that no one ever mentioned, I found it by searching in the code of other modules...
