Pictures from themes
TrekRed
Post by TrekRed »
How to display pictures from attachments topics on the portal? Example:
To the size it was about the same as in the photo!
Re: Pictures from themes
This would require extensive changes.
TrekRed
Post by TrekRed »
Kirk, Any extension requires change. I will be grateful!
This topic may help: http://bb3.mobi/forum/viewtopic.php?t=29
Can you connect the ideas of this extension with the portal?
The last change to this extension is 3 years ago, on .com it is set to ABD.
I will not do anything for the portal.
TrekRed
Post by TrekRed »
Kirk, the extension is shown as an example, it does not need to be changed! It is about how to add a picture as well, what to change on the portal?
