how to make the portal default
TaTay
- phpBB.com User: 3.3.0
how to make the portal default?
- phpBB.de User: Kirk
Re: how to make the portal default
Do you mean the portal as a start page?
Open
Open
root/htaccess add this at the end:
DirectoryIndex app.php/portal index.php index.html index.htmGruß Udo
TaTay
Thanks, it works fine!
Viragohelp
- phpBB.de User: Viragohelp
- phpBB.com User: Viragohelp
Hi. when I try this it breaks on me.
DirectoryIndex phpbb3/app.php/portal index.php index.html index.htm
Any ideas? I am converting my wordpress side articles into the forum side right now so I will need to figure this out. Thank you!
Here is a pic of broken view.
Viragohelp
but the folder is not at my root. I try it without the phpbb3 and just my viragohelp wordpres side loads..... viragohelp.com loads wordpress side. viragohelp.com/phpbb3/index.php loads phpbb
Your
An alternative would be this:
Create a file called
Load this file into your forum root (where the config.php is located).
Open:
Add this at the very end:
.htaccess is located in the directory phpbb3An alternative would be this:
portal.php with the following content:Code: Select all
header("Location: https://viragohelp.com/phpbb3/app.php/portal");
exit;Open:
root/.htaccessAdd this at the very end:
DirectoryIndex portal.php index.php index.html index.htmGruß Udo
Viragohelp
I actually tried that yesterday and it worked! Thank you very much. My website is barely covering itself but I went ahead and sent 20 bux to board 3. I donated before but it was few years back. This extension in my opinion is one of the best for phpbb. I have another question but I will make a new post for it. Thank you!
