Portal on phpBB 3.3
Solidjeuh
phpBB.com User: Froddelaar
Portal on phpBB 3.3
Post by Solidjeuh »
Hello,
I installed Board3 portal on phpBB 3.3, all works, but I get a warning in ACP
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/vhosts/solidjeuh.be/httpdocs/ext/board3/portal/acp/portal_module.php on line 128
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/vhosts/solidjeuh.be/httpdocs/ext/board3/portal/acp/portal_module.php on line 448
Yeah I know, phpBB 3.3 is still not released, but i like to test things ;)
Re: Portal on phpBB 3.3
Open: root/ext/board3/portal/acp/portal_module.php
Find on line 128: continue;
Replace with: break;
Find on line 448: continue;
Solidjeuh
Post by Solidjeuh »
Great! Thank you
Mike-on-Tour
phpBB.de User: Mike-on-Tour
phpBB.com User: Mike-on-Tour
Post by Mike-on-Tour »
There are some more lines with 'continue;': 236, 241, 336, 346, 384, 529, 536 and 600). I advise to use Ctrl-H to find and replace them all.
juanpa
Post by juanpa »
Hello,
There are also bugs on News and Last Bot modules.
For now I had to desactivate them.
What kind of error is shown?
juanpa
Post by juanpa »
When navigate with module Last message activated to:
forum/app.php/portal
I got a blank page with this error message:
Fatal error: Uncaught Error: Call to undefined method board3\portal\portal\fetch_posts::add_lang() in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/news.php:122 Stack trace: #0 /htdocs/mywebsite.com/forum/ext/board3/portal/controller/main.php(255): board3\portal\modules\news->get_template_center('26') #1 /htdocs/mywebsite.com/forum/ext/board3/portal/controller/main.php(183): board3\portal\controller\main->get_module_template(Array, Object(board3\portal\modules\news)) #2 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/HttpKernel.php(151): board3\portal\controller\main->handle(Array) #3 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/HttpKernel.php(68): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(phpbb\symfony_request), 1) #4 /htdocs/mywebsite.com/forum/app.php(35): Symfony\Component\HttpKernel\HttpKernel->handle(Object(phpbb\symfony_request)) #5 {main} thrown in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/news.php on line 122
I just notice that if I desactivate the news module I got an error with Last members module
Fatal error: Uncaught Error: Call to a member function sql_query_limit() on string in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/latest_members.php:82 Stack trace: #0 /htdocs/mywebsite.com/forum/ext/board3/portal/controller/main.php(250): board3\portal\modules\latest_members->get_template_side('8') #1 /htdocs/mywebsite.com/forum/ext/board3/portal/controller/main.php(183): board3\portal\controller\main->get_module_template(Array, Object(board3\portal\modules\latest_members)) #2 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/HttpKernel.php(151): board3\portal\controller\main->handle(Array) #3 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/HttpKernel.php(68): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(phpbb\symfony_request), 1) #4 /htdocs/mywebsite.com/forum/app.php(35): Symfony\Component\HttpKernel\HttpKernel->handle(Object(phpbb\symfony_request)) #5 {main} thrown in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/latest_members.php on line 82
If I desactivate Last members I can access to the portal. Now let's try with Last Bots
Now I got directly the error in ACP when I activate Last Bots module
Fatal error: Uncaught Error: Call to a member function set() on string in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/latest_bots.php:127 Stack trace: #0 /htdocs/mywebsite.com/forum/ext/board3/portal/acp/portal_module.php(488): board3\portal\modules\latest_bots->install(27) #1 /htdocs/mywebsite.com/forum/includes/functions_module.php(676): board3\portal\acp\portal_module->main('\\board3\\portal\\...', 'modules') #2 /htdocs/mywebsite.com/forum/adm/index.php(81): p_master->load_active() #3 {main} thrown in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/latest_bots.php on line 127
What PHP version are you using?
juanpa
Post by juanpa »
HI,
I am on 7.2 php version, I have would like to switch to 7.3 (recommanded by my web Host) but because of some incompatibilities with phpBB3 I switch to 7.2
My PHP version did not change since I update phpBB3, and the Board3 did no have errors before this update
Edit: Try to switch to php 7.3, same errors:
News module:
Fatal error: Uncaught Error: Call to undefined method board3\portal\portal\fetch_posts::add_lang() in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/news.php:122 Stack trace: #0 /htdocs/mywebsite.com/forum/ext/board3/portal/controller/main.php(255): board3\portal\modules\news->get_template_center('28') #1 /htdocs/mywebsite.com/forum/ext/board3/portal/controller/main.php(183): board3\portal\controller\main->get_module_template(Array, Object(board3\portal\modules\news)) #2 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/HttpKernel.php(151): board3\portal\controller\main->handle(Array) #3 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/HttpKernel.php(68): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(phpbb\symfony_request), 1) #4 /htdocs/mywebsite.com/forum/app.php(35): Symfony\Component\HttpKernel\HttpKernel->handle(Object(phpbb\symfony_request)) #5 {main} thrown in /htdocs/mywebsite.com/forum/ext/board3/portal/modules/news.php on line 122
Line 122
		$this->user->add_lang('viewforum');
EDIT 2:
I omit to tell that at the begining just after the phpBB update I got this error in ACP
phpBB a rencontré une erreur lors de la construction du conteneur en raison d’une extension installée. Pour cette raison, toutes les extensions ont été temporairement désactivées. Elles seront automatiquement réactivées dès que l’erreur de conteneur sera résolue. Pour cela, commencez par purger le cache de votre forum. Si cette erreur persiste, veuillez visiter le forum de support phpBB.com (en anglais) ou le forum de support phpBB-fr.com (en français).
Exception : The file "/htdocs/mywebsite.com/forum/ext/board3/portal/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 12 (near "- @board3.portal.columns").
#0 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/htdocs/team-bo...')
#1 /htdocs/mywebsite.com/forum/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /htdocs/mywebsite.com/forum/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /htdocs/mywebsite.com/forum/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /htdocs/mywebsite.com/forum/phpbb/di/container_builder.php(203): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /htdocs/mywebsite.com/forum/common.php(115): phpbb\di\container_builder->get_container()
#9 /htdocs/mywebsite.com/forum/adm/index.php(23): require('/htdocs/team-bo...')
#10 {main}
I fix it by removing the @ like specified in the error message.
juanpa
Post by juanpa »
Ok, today I decided to deactivate the extension, remove the data and réactive the Board3 portal.
I got this error :
Fatal error: Uncaught TypeError: Argument 1 passed to board3\portal\event\listener::__construct() must be an instance of board3\portal\controller\main, string given in /htdocs/mywebsite.com/forum/ext/board3/portal/event/listener.php:52 Stack trace: #0 [internal function]: board3\portal\event\listener->__construct('board3.portal.m...', 'auth', 'config', 'controller.help...', 'path_helper', 'template', 'user', 'php') #1 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/ContainerBuilder.php(1176): ReflectionClass->newInstanceArgs(Array) #2 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/ContainerBuilder.php(634): Symfony\Component\DependencyInjection\ContainerBuilder->createService(Object(Symfony\Component\DependencyInjection\Definition), Array, false, 'board3.portal.l...') #3 /htdocs/mywebsite.com/forum/vendor/symfony/dependency-injection/ContainerBuilder.php(1281): Symfony\Component\DependencyInjection\ContainerBuilder->doGet('board3.portal.l...', 1, Array, false) #4 /htdocs/mywebsite.com/forum/ven in /htdocs/mywebsite.com/forum/ext/board3/portal/event/listener.php on line 52
EDIT : Finally the solution is here: https://www.board3.de/viewtopic.php?f=72&t=11671#p38505
