Hi I tried the pinup Ie upload the install folder, it keeps asking me to login, this is an old version of Portal Im not sure of the version but it was around the August 08 timeframe.
Mybe the older version dont work with uninstall ?
Appreciate any help
Tried uploading install folder and running /intall.php
Hi trying to uninstall older version 1.0. I think, wont uninstall ?
Trying to unistall portal
