I just installed board3 on my forum site, but the blockI just installed board3 on my forum site, but the blocks aren't coming, why?
Installed phpbb version 3.2.7
installed board3 version 2.1
Portal blocks are not displayed
- phpBB.de User: Kirk
Re: Portal blocks are not displayed
What blocks are not displayed?
Did you set the permissions for these blocks correctly?
This portal extension is too old, the portal permission does not appear and script gives the php warning on phpbb 3.2.7
Hello! I need some help with Portal. Something similar to this problem above. I have phpBB v3.2.8 installed and Portal v.2.1. There are settings of Portal in ACM in tab Extensions - Portal Modules. All blocks can be edited, added, moved, etc. But none of them are shown on home page. How to fix this?
Did you set the modules under 'Enable module' to yes?
Yes, sure. I firstly checked this. And Module permissions are for all. Maybe, if you look at this site, you will see something wrong - freerollpokerclub.ru
That's up to your style, in prosilver everything is correct.
But i have prosilver installed and one daughter style based totally on prosilver with minimum css changes.
I see... And now I have another issue... Now there is an "Information" message in Style Management tab: Could not get the style configuration file. What is that? I can't activate or deactivate installed styles.
This problem has nothing to do with the portal, please ask at phpBB.com
