2 Questions Changing color on block titles
Neves
phpBB.com User: Neves Projects
Post by Neves »
1- Where can I change the font color in board block titles in dark vision?
and
2- The size of board block links ?
please see pic
Thanks
Re: 2 Questions Changing color on block titles
1. Go to root/ext/board3/portal/styles/prosilver/template/portal/modules/ open all html files in this directory
Find:
{$TITLE}
Replace with:
<span class="b3p-blocktitle">{$TITLE}<span>
Open: root/ext/board3/portal/styles/dark_vision/theme/portal.css
at the end insert this:
.b3p-blocktitle {
	color: #ffa500;
Change the color to your liking.
In the end "ACP -> General" --> purge cache
2. The size of the links results from the link text.
Neves
Post by Neves »
Thank you
Return to “Styles Support”
