SubSilver2 Portal Theme (PHPBB 3.2.2)
SugarD-x
phpBB.com User: SugarD-x
Post by SugarD-x »
As per the instructions provided, I have gotten Board3 Portal running just fine on PHPBB 3.2.2, however I'm running into a bit of a problem because my current forum theme uses SubSilver2 as a base, (which is also installed on my forum). As my understanding goes, PHPBB dropped direct support for this theme in either PHPBB 3.1 or 3.2, (I can't remember which off-hand), because it wasn't "responsive". Now the theme itself still runs fine for those that have it installed in PHPBB 3.2.2, however Board3 Portal no longer includes modules for it, and the portal is looking for specific files in my theme and SubSilver2 which don't exist because of such.
Is there an existing copy of the SubSilver2 theme modules for Board3 Portal that are compatible with PHPBB 3.2.2 and the latest modified version of Board3 Portal that was unofficially released to work on said forum version? If not, what is the latest released version of Board3 Portal that contains the theme modules that will work, and do any changes need to be made to it? (If I have to pull the modules from an older version of Board3 Portal and modify them, I don't have an issue with that as long as I know what needs to be changed in order to make it all work).
Any help is appreciated!
Re: SubSilver2 Portal Theme (PHPBB 3.2.2)
There are no instructions for Subsilver2 under phpBB 3.2.2.
Ask the Style Author.
SugarD-x
Post by SugarD-x »
The style author is PHPBB themselves. :P
I have no issue using SubSilver2 with PHPBB. My issue is getting it working under Board3 Portal because its modules are no longer offered with the extension itself.
Subsilver2 is no longer available for phpBB 3.2.x.
There are no modules for it either.
Solidjeuh
phpBB.com User: Froddelaar
Post by Solidjeuh »
There is a subsilver based style for 3.2.2:
https://www.phpbb.com/customise/db/styl ... subsilver/
SugarD-x
Post by SugarD-x »
Solidjeuh wrote: 10. August 2018 18:02 There is a subsilver based style for 3.2.2:
Unfortunately I'm looking for support for the original SubSilver2 theme, as I use a different theme that is based off of it.
The original Subsilver2 was only developed until 3.1.x. There are no modules for it either.
Return to “Styles Support”
