Your Portal Version: v 1.0.2
Boardlink: http://www.newoutriders.com/nortest/phpBB3/
PHP Version: 3.0.2
MySQL Version: 5.0.16
I uploaded the "root" files only. Made the edits to the regular files, but have not yet uploaded them as the instructions say to not upload the changed files until the install is run.
I searched these forums and fould all types of answers, tryied them all, but none have worked.
I even went to viewtopic.php?f=24&t=623 this answer in the FAQ, but still get the same:
PInUp Error
You must be logged in as an admin.
I did notice that in the "Fix" in the FAQ viewtopic.php?f=24&t=623 the first part of the answer said:
if( $user->data['is_registered'] && $auth->acl_get('a_board') )
but the install.php has no such word "a_board" only "a_" I did delete that line along with the second & it still didnt work.
Was I supposed to upload the "changed" files first even though the instructions do not state to do so?
==EDIT==
I am now getting
General Error
SQL ERROR [ mysql4 ]
Table 'norbb3test.phpbb_portal_config' doesn't exist [1146]
I did upload the constants file as discussed in: viewtopic.php?f=24&t=554. I even started over and reuploaded it, but am still getting the error:
Should I just start all over?
PInUp Error
Re: PInUp Error
Try this installer: download/file.php?id=130
Delete it straight away after installation!
Thanks for the hint - that was changed with 1.0.2 - the FAQ was older. Corrected.DianaRae wrote:I did notice that in the "Fix" in the FAQ viewtopic.php?f=24&t=623 the first part of the answer said:
Re: PInUp Error
thanks, that worked.
