Your Portal Version: 1.0.2
Boardlink: http://risingsun.xtreemhost.com
I have Board 3 portal installed and it works for prosilver, but I would like to use it with the WoW Alliance Style, can any help me adjust this style to work with board 3 portal.
Thanks in advance,
RedWolf
Style Help - WoW: Alliance
Re: Style Help - WoW: Alliance
I would.. but Alliance smell funny.
Does that mean your not going to help me LOL ![Lächeln :)](./images/smilies/icon_e_smile.gif)
Please, I like the layout of alliance better than WoW Moonclaw
For a start your using the prosilver block templates when that style is based on subsilver2, use those ones instead.
As you're using prosilver block templates you may have tried using the prosilver edits, remove them and try the subsilver2 ones instead.
Let me know how it goes.
OK will do, have to go to work soon, so I will try it tonight or tomorrow. Thanks for the advice
That worked! thanks for the advice
