First time user of Portal need advice on code
auntie_bi0tic
Post by auntie_bi0tic »
I have just started to set up my site and am so pleased to find your portal appears to work!
My question is with code.
I have tried to place the code for google translate in a custom module but nothing shows up.
The code is
[b]<div id="google_translate_element"></div><script type="text/javascript">
function googleTranslateElementInit() {
  new google.translate.TranslateElement({pageLanguage: 'en'}, 'google_translate_element');
</script><script type="text/javascript" src="//translate.google.com/translate_a/element.js?cb=googleTranslateElementInit"></script>[/b]
I have tried clicking both options in module
Activate BBCode for the custom block
BBCode could be used in this box. If BBCode is not activated, HTML will be parsed.
But code does not appear.
Any advice please. this is important to me as I would like to use code in my site
Thx in advance
Re: First time user of Portal need advice on code
I just tried it, it works.
Try it like this:
This one
[b][/b]
is BBCode not html.
BBCode must be disabled.
