How much time and effort would it be to code the forum itself with both columns showing.
As of now you have an option to pick either the right, or left to show. I'd love to show both.
Coding-Columns
Re: Coding-Columns
If someone wants to tell me how to do It, Ill do it myself.
Re: Coding-Columns
It is possible but not recommended.
Open:
Find:
Replace with:
The general settings in the acp must be set to "Column to display on all pages" on left.
There are no further instructions, also think of smaller resolutions.
Open:
/ext/board3/portal/event/listener.php
Find:
'right' => $this->config['board3_show_all_side'] == true,
'right' => $this->config['board3_show_all_side'] == false,
Re: Coding-Columns
Thanks.. Now, may I ask why its not recommended? As in what? Thanks..
- phpBB.com User: Froddelaar
Re: Coding-Columns
That's the reason why I don't use the side bars. I just use the center.
Looks better, and you can add whatever you want.
Re: Coding-Columns
Gotcha thanks.
Re: Coding-Columns
Hey dude, I do see that now, in the forum it's strunk.. where would I be able to edit the dimensions to make it bigger?
If I could make the middle wider that would be good, and maybe the columns themsevles as well
