Cannot access Extensions tab
Jedis
Post by Jedis » 6. May 2017 22:35
Hello,
I am running phpBB3 v3.1.10 and board3 portal. I can no longer get to my Extensions tab:
Fatal error: Uncaught exception 'RuntimeException' with message 'Failed to obtain latest version information.' in /home/jedis/forums/phpbb/version_helper.php:295 Stack trace: #0 /home/jedis/forums/phpbb/version_helper.php(234): phpbb\version_helper->get_versions(true, false) #1 /home/jedis/forums/phpbb/version_helper.php(213): phpbb\version_helper->get_versions_matching_stability(true, false) #2 /home/jedis/forums/ext/board3/portal/includes/version_check.php(79): phpbb\version_helper->get_suggested_updates(true) #3 /home/jedis/forums/ext/board3/portal/acp/portal_module.php(163): board3\portal\includes\version_check->check() #4 /home/jedis/forums/includes/functions_module.php(674): board3\portal\acp\portal_module->main('\board3\portal\...', 'config') #5 /home/jedis/forums/adm/index.php(81): p_master->load_active() #6 {main} thrown in /home/jedis/forums/phpbb/version_helper.php on line 295
Any ideas?
Re: Cannot access Extensions tab
Post by Kirk » 7. May 2017 09:27
You have an outdated portal version, the latest is this: https://www.board3.de/viewtopic.php?f=40&t=11060
