Author: Talonos
Extension Description:
This extension will add a Top poster This Month module to your board3 portal that will display the user with mosts in the current month
block can be used in Left/Right only
block will not display anonymous OR banned users
ACP:
enable/disable the displaying of admins/mods with the block
enable/disable the displaying rank text
enable/disable the displaying rank image
chache update: change how often the module will update its cache. 1-99 minutes (10 minutes default) for large sites a higher number is recommended to reduce SQL querie calls
Extension Version: 1.0.0
Download:
http://pretereo-stormrage.co.uk/viewtop ... p=375#p375
Installation:
1. Download the latest release.
2. Unzip the downloaded release.
3. In the `ext` directory of your phpBB board, create a new directory named
`talonos`.
4. Copy the `b3pajaxshoutbox` folder to `/ext/talonos/` if done correctly, you'll have the
main extension class at (your forum root)/ext/talonos/b3pmonthlyposter/composer.json
5. Navigate in the ACP to `Customise ‐> Manage extensions`
6. Look for `Board3 Top Poster This Month` under the Disabled Extensions list, and click its
`Enable` link.
7. add the module to your portal via the menu at ACP ‐> Extensions ‐> Portal ‐>
Portal Modules ‐> add modules ‐>Top Poster This Month' (Left/Right modules only)
Revision information:
1.0.0
Initial release for Board3 portal
