Portal as Home
Xx_iDon_xX
phpBB.com User: Xx_iDon_xX
Portal as Home
Post by Xx_iDon_xX »
Hello all, I would like it so that when people visit my site www.idonmodding.com that the portal would be the default/home, can anybody help?
Re: Portal as Home
Xx_iDon_xX
Re: Portal as Home
I did everything as said but I don't have the second file that it says to delete, also is there a way to remove the portal from the middle and just leave the first portal that shows on the screen shot and just idon modding forums? instead of portal portal idon modding forums I want portal idon modding forums
https://gyazo.com/077935192e3362a56a1dcbc8fbf26cfc
Re: Portal as Home
Navigate to the directory root/ext/board3/portal/styles/prosilver/template/event/ and delete those two files:
overall_header_breadcrumb_prepend.html and overall_footer_breadcrumb_prepend.html
