Board Removal Instructions
flat_webb
Post by flat_webb »
Nothing
Removed files added to phpbb installation.
Are there any instructions available to perform a successful (and complete) removal of the portal from my board? In particular I want to ensure there are no alterations made to my sql database left in place....
many thanks,
:mrgreen:
Re: Board Removal Instructions
Just undo the changes from the install.xml
flat_webb wrote:In particular I want to ensure there are no alterations made to my sql database left in place....
The installer (option: uninstall) should take care of it.
May i ask why you have decided to remove the portal?
flat_webb
Post by flat_webb »
I made a bit of a mess of my live board so have been starting much of it again from scratch. I've got a test board up now as well so will be trying out the portal with that to get it working just how I want before deploying it back onto my live board....
