IS there a Portal Update Available?
leggyuk
Post by leggyuk »
Your Portal Version: 2.1.0-rc2
Boardlink: http://www.dogclanuk.com/
Nothing
Posted this Post
Hi guys,
Is there any plans to release an update to the portal to coincide with the new 3.2.0 phpBB.
Thanks for the great work and thanks for reading.
Re: IS there a Portal Update Available?
The portal works with 3.2.0
You have to make some changes.
leggyuk
Post by leggyuk »
Cheers for that Kirk, much appreciated.
I will implement it this weekend,
Thanks for your time and efforts.
Lance
Post by Lance »
Is there an English translation of the instructions for phpBB 3.2?
When I try to translate that page, the best I can figure out is to delete a lot of stuff but not replace it with anything.
Or will there be a new, update Portal for 3.2?
Thanks!
"Some things are false no matter how many people believe them
while others are true whether we believe them or not."
Solidjeuh
phpBB.com User: Froddelaar
Post by Solidjeuh »
Lance wrote: 1. February 2017 15:31 Is there an English translation of the instructions for phpBB 3.2?
Thanks!
Use my files, they work on 3.2
You just need to empty your browser history and forum cache.
Download: https://www.supportforum.be/private/scripts/board3.zip
Lance
Post by Lance »
Solidjeuh wrote: 1. February 2017 17:36Use my files, they work on 3.2
https://www.froddelpower.be/scripts/board3.zip
THANK YOU!
To be honest, that was the answer I was hoping for. But it felt a bit presumptuous asking.
I really appreciate your efforts.
Jupiter
Post by Jupiter »
Curious question on the Announcements module with the 3.2 update. Why am I getting so many extra <br> added to my content text?
You can see my announcement module here: http://www.gopherpucklive.com/test/phpBB3/portal
The original post here: http://www.gopherpucklive.com/test/phpB ... 14&t=12971
Yes I realize that I have modified the template a bit. But it was adding extra spaces long before I made those edits. For every real <br> it encounters, the module is adding 3 more <br> in the output. I have even gone in the original post and removed the carriage returns, but the extra <br> still get added.
What am I missing here? Why are are <br> getting added?
Digidani
phpBB.de User: Digidani
phpBB.com User: Schtorsch
Post by Digidani »
Same here. Posted in german section: viewtopic.php?p=37087#p37087
A hint from Kirk does not effect for me. Waiting for the update - and so long I can live with these "error". :)
Jupiter
Post by Jupiter »
hmmmm.... I think I may just wait for a real update for this software. I am having permissions problems as well. Registered users can't access the portal page. Yet, logged out users can. Strange.
Jumpman
Post by Jumpman »
Kirk wrote: 9. January 2017 23:25 Hi
I have follow your link but after i did the change my portal look like icons all over, maybe be course i use the "black" style from Arty, this style is not updated yet :(
Jumpman wrote: 17. February 2017 16:37 this style is not updated yet
If this style is not updated, it does not work.
These adjustments apply only to 3.2.x.
Jumpman
Post by Jumpman »
Kirk wrote: 17. February 2017 19:54
Thanks i just found another style thats was updated, but my problem now is on the front site at my portal http://venskabsklanerne.dk/app.php/portal it only show what topic i made in GLOBAL ANNOUNCEMENTS before we could read the hole topic on the frontpage do you know how i can chage that back ?
Dwnld
phpBB.com User: Dwnld
Post by Dwnld »
First of all, no offense intended.
Basically if the end user have to make any changes to make it work, the real answer is: No it doesn't work with 3.2 without updating.
It's like you are saying "Windows 95 can run any Windows 10 program. You just have to make some changes."
AFAIK Board3 Portal's updates have always been extremely slow. It takes months to get a properly updated package for download.
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Dwnld wrote: 19. February 2017 11:43
the time is due to the complexity of board3 and they don't want to push a "faulty" update
board3 "can" run on phpbb 3.2 but needs some edits to make it visually work, there may be other bugs in the system which the creators here are proberly trying to get fixed for a proper release.
Solidjeuh
Post by Solidjeuh »
Pleaseeeeeeeee releaseeeeeeee board3 portal for phpBB 3.2 :lol:
it's working, but a few extension authors are waiting for an official release to update their portal addons :D :D
