new block image random
grazia
Post by grazia »
This is the script
I Found on line A script that loads image to the root image, shows the chance, it would like to create a portal block
tnk
Re: new block image random
grazia
Post by grazia »
ok than , test
grazia
Post by grazia »
grazia wrote:ok than , test
i have this message
erro un the block
Unable to find template "@marc_b3pweather/marc_b3p_weather_side.html" (looked into: ./ext/marc/b3pweather/styles/prosilver/template, ./ext/marc/b3pweather/styles/all/template, ./ext/marc/b3pweather/styles/all/template) in "portal/portal_body.html" at line 58
already is complicated for me as well, then if I have to enter the causal image module,, I mad
