Your Portal Version: 2.1.0
Boardlink: http://paixnidi.org/mboard
Nothing
Searched online
Hello. I installed the portal for an internal forum that just few users will use. It is located in a subfolder of the main site. My problem is that the "Portal" link redirects to a non existent page. mysite.com/subfolder/app.php/portal.
The weird thing is that the correct URL seems to be mysite.com/subfolder/app.php which works just fine. How can I change the portal's link from .../app.php/portal to plain .../app.php?
Wrong link in portal Button
Re: Wrong link in portal Button
You can set it so that appears yourdomain.com/portal
Go to ACP/server settings on Enable URL Rewriting: set to yes
I enabled the option but still I get a 404 page.Kirk wrote:Hi
Now it redirects to http://site/subfolder/portal which is not correct. The portal for some reason is on http://site/subfolder/app.php.
I just want to delete "/portal" from the link
I think I didn't explain correctly. After the portal installation there is no "portal" subfolder in my FTP. I tried what you told me but now the link redirects to http://site/subfolder/portal which is not correct. Again the correct URL is http://site/subfolder/app.php which takes you to the portal by typing it.Kirk wrote:Hi
